New c1
Socohreak
Canada
Hi,
Long time lurker who just got a dash cam.
So I've set it all up, put in new memory card, put it in my car and was able to pull off a few recordings.
I had couple of questions though. I read that a dash cam cable would be required to run this as a dash cam. Where could I get one? Or is there one I can modify to make work for this camera?
Second question. The unit came with a cable which of I've found no mention anywhere. This is a mini-B end on one end with a black abd red to one connector. The second is a yellow and black to a separate connector. What is this for?!
Thanks
I think that extra connector is for powering the camera and get video out ( low resolution ) for FPV use on a RC quadcopter or plane
I dident get that cable with my sample, but when i got mine it was very erly days and RockThinking sent me one for testing, sadly my C1 is now dead :( one evening it just put out smoke for some reason, so i think that was the battery giving up.
The innovv cameras are a bit tricky as they use that non standart port on the camera, so any old USB wire just wont work with it.
But let me highlight @RockThinking then i am sure he can help you out when he see it.
I have a surplus wire myself but those are just the PC cables, so no need to send you one of those as they wont work as a dashcam cable.
The 1 dashcam cable i do have i use on my C3 in the car, so that one i will not part with.
O and welcome to the forum Socohreak.
Thank you, Kamkar1,
Hi,
Thanks
https://www.ebay.com/itm/371304242126
Try to find cable from above link.
That cable should work perfectly.
Thanks
