New cable w/o new dash cam?
RaybanRJ
Well after two and a half years of putting power banks on my RSC nano dash cam cable and bending the end of the cable so many times it finally bit the dust and my dash cam doesn’t work unless I fold over the cable in a certain angle then it works so I’m wondering if it’s possible do they even sell the cable without having to buy a whole new dash cam? I’ll try some places like Best Buy and Staples tomorrow
DT MI
Michigan
More than my wife thinks I need.
It looks like a standard USB connector on both ends so finding a new cable should be fairly easy. If not at Best Buy/Staples just about any computer store should have a large selection.
Edit: Get one with a 90 degree connector to minimize the need to flex the cable as much. If only straight cables are available you should be able to pick up a 90 degree adapter as an alternative.
RaybanRJ
RaybanRJ
Thanks I’ll definitely check. Yeah I should’ve mentioned that one end is the standard USB and the other one is the Mini USB (I think it is called). Looks like Amazon has them but I’m not sure what the standard length is needed for a car that would go from the windshield rearview mirror down along the top down the a pillar and under the dash
DT MI
Michigan
...I’m not sure what the standard length is needed for a car that...
How long is your current cable? 'Standard' lengths are usually 1, 2, 3, 4, 5, 6, 8, 10, 12 and 15 feet.
See my edited post about 90 degree termination to minimize flexing.
RaybanRJ
RaybanRJ
I found the instruction manual for the dash cam but they’re not saying how long the cable was. I would sure like a link to that post you made if you have it handy
DT MI
Michigan
First post in this thread. I edited it as you were responding. Just a comment about getting a cable with a 90 degree end to minimize the amount of flexing in the cable when attaching to the camera. Something like this (just be mindful of the direction - 'right' and 'left' are implemented differently from one manufacturer to the next.
https://www.amazon.com/gp/B004NO0L4O
RaybanRJ
RaybanRJ
Oh no you’re right I forgot about the 90° angle I need that, and here I just ordered this one off Amazon, I wonder if I can cancel my order I’ll give it a try
RaybanRJ
RaybanRJ
Yep I was able to cancel, I got to be more careful because I need that one with a 90° angle. The flexing occurs only on the larger USB end because I connect a battery pack or a power bank to the larger end and that’s where the flexing occurs when I hide it in the centre console of the car, there’s no flexing on the 90° and where the dash cam is.
RaybanRJ
RaybanRJ
Ordered this one, fast delivery, should work fine.
