smiley1081
- Feb 6, 2016
- Italy
Anyway i am not buying from Amazon before they make a Danish warehouse.
Is that planned?
Well, Denmark is about a sixth of Italy, per surface, and we only have four main depots.No.
I might also fail this statement but i will try my very best.
Just leave the EU, when we did things like this started popping up everywhere:You should enlarge Denmark!
This is a real deal. But it seems like is not for everyone.I see there is a lightning deal for the A129 duo pro on amazon for the next 7 hours for $199.92 shipped from Viofo. In stock sept. 9-20
https://www.amazon.com/gp/B07RXQJ148
Thank you for your advice. I do not understand if it is using the RCA Yellow-Red-White connector into my tablet. Please explain in more detail.The AV out ports are usually on all the time when the camera is on, also recording, at least thats my understanding, but i have never experimented with the AV out of any dashcam, but my old 4 channel analog setup i had connected to my 2 DIN head unit AV in.
you are probably best off looking at the road in difficult conditions. I did try driving my car while looking at the LCD screen, and it was possible but no doubt also highly dangerous and not to be recommended.
Thank you for a very in depth reply. The "Tablet" is the Dasaita 10.2" Rotatable Android 9 radio that has lots of connections (I have discovered from the many suggestions)Some high end cars have, or use to have a HUD like display on the windscreen where proper night vision / FLIR imagery could be displayed, but i am not sure if they still have that or it was just a passing fab.
But these systems have AI and dont just rely on the driver seeing the obstacle ( pedestrian / animals / parked car ) mind you there is a display in the speedo, but a driver should not be looking at that and surely not at speed.
To use the AV out of the dashcam you need the adapter wire, this is probably a 3.5 mm jack plug in the camera and typical a RCA style plug for the TV signal ( just like antenna plugs on the back of a TV in the old days )
And any sound will usually come over one or two phone plugs, like used for audio signal in stereo equipment for many years.
So your tablet would need to have a RCA plug on it, and i have never heard of such a tablet, tablets typically just have a USB input and maybe a mini jack for headphones.
Regular cameras will also get blinded by on coming cars and adjust to compensate for this, often making the image darker so you can see even less., thats why car makers use thermal FLIR cameras as they dont see all the hear of other card headlights just the little of heat from the bulb.
There have been some driver aid gadget attempts, but none successful as far as i know.
it doesn't see in the darkThere are people using the SuperNight Vision aspects
There has been one very successful night driving aid, so successful that it is found on almost every car produced in the last century, even though it is not a legal requirement, at least not in the UK - headlights.There have been some driver aid gadget attempts, but none successful as far as i know.
I'll be dipped in beams!There has been one very successful night driving aid, so successful that it is found on almost every car produced in the last century, even though it is not a legal requirement, at least not in the UK - headlights.
