Like PedroN, I was hoping for a fix for the oversharpness. I wonder how long until we get that firmware ?
can the GPS set to off in the setup?I was hoping for the GPS to be really turned OFF when set that way in the menu.
maybe just take the GPS module off and use the plain attachmentI was hoping for the GPS to be really turned OFF when set that way in the menu.
That won't work for me as i remove my camera every time and i personally don't want to keep removing and plugging back in the power each time. I'm not to lazy, i just don't like the wear and tear on the connection,despite what others may say about it. I had a good Modem ruined by doing that. I used to unplug it from the modem itself instead of the wall because it was easier. That connector eventually failed and i had to but a new modem. Also i think the thin mount provided won't work with the Cpl filter from what i've read. My main reason for getting the gps mount was so i could have a permanent hard wired connection and just grab the camera each time i get out of the car. So,,yeah, i'd very much like to see a new firmware that truly turns off gps when selected.
If you don't mind me asking.. why do you remove it every time?That won't work for me as i remove my camera every time....
It's a discrete cam when installed high up with the lens just a wee bit below the dots. Is your area that bad?I don't want it to get stolen.
I understand your concern even if that is a cheap cam the insurance deductible can be costly to repair/replace a side window.It's a discrete cam when installed high up with the lens just a wee bit below the dots. Is your area that bad?
Yes according to viofo's change log.Anyone already tested the new firmware? Is the freeze fix really the only improvement?
Too bad there's nothing done about the exaggerated sharpness
Change log:
1.Fixed: Camera freezing while showing XXXX on screen.
v4 firmware camera settings | A119S | 2 | ||
How can modify firmware for Large font. ? | A119S | 0 | ||
V | A119S Unable to Dowload Firmware | A119S | 2 | |
T | VIOFO a119s FIRMWARE | A119S | 72 | |
Viofo A119S Official Beta firmware | A119S | 57 |
