Hi,
I attempted to upgrade the firmware on my DR500GW-HD yesterday but the upgrade seems to have failed and, worryingly, something more severe appears to have gone wrong with the camera as a result.
Prior to the upgrade, I was running v1.009E of the firmware with no issues at all. The camera worked perfectly and I was able to format SD cards directly from within the camera. I attempted the upgrade to v1.011E from a freshly-formatted, brand new, SanDisk Ultra 32GB SD Card. I know the card works because I had used it in the camera for the whole of the previous day without any issues. I also did a low-level format using the SDFormatter application prior to installing the new firmware on it.
I attempted the upgrade with the engine running in order to prevent the upgrade from failing. I also have the Blackvue connected via a PowerMagic.
From what I can tell, the camera has no firmware installed on it, and it appears to be running solely from the firmware on the SD card (if this is even possible?). I think this because when I install a freshly-formatted, blank SD card into the camera, an array of LEDs light up and, eventually, I get Korean woman repeatedly telling me, "Initialising the SD card". This continues until I pull the power supply from the camera. It's never taken this long before on previous upgrades. When I then inspect the contents of the SD card on my Mac, it just contains the following empty folder structure and nothing more:
BlackVue
Application
Viewer for Mac
Blackvue Viewer.app (which is zero bytes on disk)
I am also unable to format SD cards from the camera now. The same thing happens with both my new SanDisk SD card and the original Pittasoft Sd card that came with the camera so i do not suspect the SD cards I am using are dodgy.
Does anybody know if there is a way of forcing an upgrade of the firmware onto the camera by hacking the version.bin file (which is just a text file)? The camera seems to think it has v1.011E installed on it (I can tell this by checking the version numbers from the iPhone app when connected over wi-fi) but I would say it is an incomplete install (for reasons unknown to me).
I'm wondering what might happen if I were to increment the version number of the firmware in Version.bin to:
[firmware]
version = 1.0111
model = 500GW
language = English
[software]
version = 2.101
model = 500GW
language = English
[config]
version = 1.040
model = 500GW
Note that I added an extra 1 to the end of the firmware version string. I guess I could use 1.012 but that might cause problems if Pittasoft ever release a v1.012E version of the firmware.
I have contacted Pittasoft about this. I've only had the camera a couple of months after buying it from a UK authorised reseller (HIDS4U).
Please help me restore my Blackvue back to how it used to work!
Thanks,
Steve
