Hi.
I have an Eken action cam I got from China for recording my fishing and occasional go-karting, biking, and a few interesting drives on my car through the hilly countryside. So I have experience with cams, mounts, SD cards, power banks, etc. But I'm definitely a newbie to dash cams so I hope you can help me out.
Here are some of the criteria I thought of and read about:
So many to choose from so I'm hoping you guys can narrow down my choices. Thanks for the help.
- Front and rear
- Turn off automatically when car is turned off. Will cam automatically turn on and record when car is started? Or have to do that manually? That's easy for the front. Doing it manually for back could be annoying.
- Do some come with a remote? For the rear that would be useful instead of every time opening back door and turning on. On my Eken, I have a wrist remote with ON and RECORD buttons.
- Looping
- Max. SD card size - Probably not an issue since I'm guessing I don't need much. If I were going on a long trip I suppose 64 gb would make sense. But if the camera loops over, and longest drive is say 2-3 hours to the cottage, then I guess a 32 gb would be enough for each. I rent cars for long trips.
- 10 minute video files like my Eken action cam - stops and starts after every 10 minutes so I have manageable files to work with uploading onto computer
- Preview screen and playback- To see what view I have and go through the footage on the actual cam
- Suction mount and mount to clip onto mirror - When I use my Eken for driving, I use the bicycle handlebar mount and clip it behind the rear view mirror. Seems less obstructive that way.
- Good at night - Live in the city but sometimes driving out in the country at night time, like when at the cottage.
- Power cord - Long enough to run along the top of the windshield and down the A pillar of the car, then under the glove box and to the 12V outlet. And for the rear, I suppose that will have to be really long and run under the trim/panels along the bottom of the doors and up to the car battery?
- Can handle -20 degrees Celsius - Live in Toronto area so it only gets that cold a couple or a few times a year at night.
- Wide angle lens to capture as much as possible
- Battery Use - Will it drain and shorten the life of the car battery? Should I get a dedicated 20,000 mah power bank? Particularly for the rear so I don't have to run wires under the panelling of the car doors?
- Parking mode - Only need this for when car is at work for 8 hours in the parking lot (rear only) or for a couple hours at the mall (front and rear). Don't need it when parked at home. So is there an option on the camera to activate parking mode only when needed?
- Budget - Trying to keep closer to lower end than higher end as I don't have a lot of money to spare. Not a garbage cam but something decent.
