Frustrated User
- Dec 6, 2017
Unfortunately, the DR750S-2CH product is a disappointment in so many ways:
* The resolution is not as sharp as I would expect from 1080p cameras – particularly, the rear one.
* There is a tremendous amount of glare from both cameras – particularly the rear one (even though it has a polarizing filter attached).
* Both cameras RELENTLESSLY record video clips when the vehicle is in my garage (with the doors closed). This is true whether or not anything is happening the garage (such as use of clothes a washer and/or dryer.) I have tried all sorts of different settings... including, but not limited to, having all G-SENSOR (PARKING MODE) settings set to "Off" and the MOTION DETECTION (PARKING MODE) setting set to "Off". When all four of these settings are set to "Off", the cameras relentlessly record in Normal Mode (i.e., as if I was driving). When you look at the video clips, it often looks as if you were looking at photos, rather than video clips. In other words, you don't see any movement.
* I suspect that the relentless generation of video clips is having a negative effect on my vehicle battery – despite the use of a Power Magic Pro unit.
Any suggestions?
Any suggestions?
