And how does the registrar conduct - without a card, is there video on the AV output from the registrar to the TV?I've tried
is that the proper way to do this?
I think it is how I've done a few other bootloader installs before with other cams but I can'r remember much of them since it's been years ago.Yes, I can see the video through the app without a card. There does not seem to be any fault in the cam or current FW. Very strange.And how does the registrar conduct - without a card, is there video on the AV output from the registrar to the TV?
This is good, 139 is normal !!Yes, I can see the video through the app without a card.
Win8.1 will not delete that folder. SD formatter leaves it there after formatting.
Are we sure that the FW version number you are looking at is wrong?So everything seems right and nothing broken, yet it still shows the same old FW on the app- that's why it's baffling me
Would it be worth someone sending you the actual file if possible? Seems to be 29Mb so not sure the best way.Everyone else is seeing 1113, but mine still has 1028. That's with both the file link Viofio sent me as well as what appears to be the same link another tester shared, and his went to 1113 while mine won't for some strange reason. AFAIK all our cams are from the same batch, and my FW did update for the first GPS bug fix FW but it didn't need a bootloader for that.
And fresh from a full overwrite with sdformatter the system information folder is still there and still cannot be deleted or cut by W8.1 Even my instantly-bricking JooVuu FW update actually did something where this is doing nothing, and that's what makes it all so frustrating.
Unzipped I'm getting something like that size for the bootloader so I'm thinking it's OK. The FW is small enough as a .bin in it's native format. I can DL from whatever file-sharing sites that will support the size if Firefox can handle them.Would it be worth someone sending you the actual file if possible? Seems to be 29Mb so not sure the best way.
Change the card, it doesn't matter what is on the card - if 139 is working properly, the first thing the will ask is to format it.Gotta be something simple but what?
it doesn't leave the folder behind, the camera recreates the file after you have formatted the card, the system volume information file is a hidden windows system file, you can see it as you have view hidden system files turned on in windows, it's not related to your problem, as long as the correct file is in the root directory the firmware will load, if the lights are flickering away on the camera when you load it then it's likely it is loading the firmware but it's the same version that you already have on the camera if it's not showing a different version number, try loading one of the earlier versions instead and then check the version numberYes, I always do an in-cam format before recording, but in this case that leaves the DCIM file on the card
D | Làm sao để tôi dùng màn hình SuZuKi XL7 để xem hình ảnh từ Viofo a139? | A139 | 2 | |
Viofo A139 and Hyundai Ioniq Hybrid | A139 | 0 | ||
M | Viofo A139 3ch not connecting to other 2 channels. | A139 | 2 | |
Stay away from the A139 and Viofo! | A139 | 82 | ||
K | Help in decision: viofo A129 duo plus/pro or A139 2ch | A139 | 5 |
