Are videos able to be viewed on the cam itself?
Stop the recording in progress with REC button (red stops flashing) You're now in "stand by mode"
Press Mic button to enter playback mode
When you press MIC to enter playback mode it will default to the most recent file, press the REC button to step back one recorded segment at a time, the screen is too small to have thumbnail view so has to be done this way for reasons of practicality
Menu = Delete, Protect, Slide Show
Center Event button = Play/Stop
Mic = Fast Forward
REC = Reverse
During playback if you press Mic it will fast forward 2x, if you press MIC again it will fast forward 4x
During fast forward playback, you press the REC button to slow down.
For example, you press Mic once, you're 2x, you press Mic a second time you're 4x, you press REC once it slows down to 2x, you press REC a second time it slows to normal speed. (etc)
