Millie (Nextbase Tech Support Engineer, above) suggests it alongside the expensive Nextbase own (what is special about it that the price is so high other than captive market?). It has been working so clearly seems compatible with the device which is listed as a compatible purchase on Amazon so I struggle to see this is the issue. Nextbase's own website simply states "An SD card designed for Dash Cam use is recommended with this model.", doesn't specify must be a Nextbase card. I've raised the issue with support so hopefully I will get some advice. If a Nextbase card was needed I would have factored the extra £45 into the dashcam price and looked at alternative brands.
Hi,
We do not suggest using any SanDisk SD card within a Nextbase Dashcam.
For a 522GW I'd recommend a Dash Cam compatible 8GB -128GB U3 Micro SD card, specifically designed for Dash Cam or CCTV usage. Using a dash cam compatible SD card instead should then allow your Dash Cam to function as designed. The card needs to have a minimum continuous write speed of 48MB/s. The SanDisk High Endurance card shows a disclosure of 30MB/s on their website.
We always suggest using a Nextbase SD card within a Nextbase Dashcam.
The best way to test whether the card is indeed causing the problem is an internal test:
1. Bring your Dashcam inside your home/office.
2. Use the provided USB cable to plug in the Dashcam to a mains socket via the port on the top of the Dashcam. Ensure the mains adaptor is at least 2 amps.
3. Please remove the SD card, then press the reset button on the underside of the Dash Cam. Then, without the SD card inserted, please turn on the Camera.
4. Ensure Parking Mode and Screen Saver are disabled.
5. Leave the camera turned on. Does it now stay on correctly? I'd recommend leaving it for 4 hours to see if any issues occur.
You can also try turning off the mains plug and waiting for the Dashcam to turn off. Then turn the plug back on. The Dashcam should automatically start without manual input. You can try this multiple times.
If no issues occur, then the issue is likely to be the SD card.
Kind regards,
Millie
Nextbase Technical Support
