Not another Parking Mode query......(yes it is)
JBailey197
Hello All,
I'll try and keep this succinct. NextBase support have been helping me troubleshoot freezing issues with my hardwired ignition-live 512GW and 512GWRC setup, and my conclusion was that the system is more stable with Parking Mode switched off. Unfortunately, late one evening just before Christmas a suspected hit & run delivery driver put a big dent in my passenger door, and of course nothing was captured. Fed up, I have now installed a Cellink Neo to allow 24/7 recording without endangering the Beemer's main battery. However, the cameras are not behaving as I would expect - and from reading many threads on here I fear that I may be no better off!
Despite a permanent live am I correct in thinking there is no way for the 512GW to record continuously, regardless of whether in motion?
Cheers,
James
M8TJT
Bexhill, East Sussex
It should trigger by the G sensor when you are hit so that you can see the culprit driving off.
J
JBailey197
The problem I had was that the system kept freezing up when using Parking Mode, and given the choice I prioritised recording my journeys. I'm fairly miffed that I had to fork out two hundred quid on a battery so that the two cameras work properly, and was hoping to make the most of it with round the clock recording. At least I can use Parking Mode now and be confident the cameras will record normally when driving away.
Jacko956
Manchester
Nextbase 512gw, 512 rear
I feel your pain. I found the front and rear are too troublesome with parking mode on. As I've mentioned in another post the battery flattens all to quickly leading to the camera freezing when when you start the car. I think nextbase should have stipulated that to use the parking mode an external battery needs to be used.
plantpowered
I'm having exactly the same issue. I have front and rear 512GW connected to a permanent live fuse, and every few days, it freezes, and doesn't record. Inevitably I don't notice this for a few days, and have therefore missed several days of recording (my wife drives it more than me and has much better things to do than check that the cam is recording!).
The Cellink Neo looks like a good option to resolve this issue, even though it really shouldn't be necessary. How are you finding it; still working well for you? Did you need any adapters for the Nextbase? How does the cam connect to the battery?
Thanks in advance.
J
JBailey197
Somewhat grudgingly, Normal and Parking Mode recordings have been faultless since fitting the Neo. Absolutely shouldn't be necessary though - and for a daily driver is a bit overkill. It just seems to be that these cameras do not like the momentary voltage and/or current drop during engine start. The Cellink app allows remote battery monitoring via bluetooth and from what I've seen, given the low consumption of the two cameras (and depending on the level of detections), I could probably run Parking Mode for at least a week. I stumbled onto the Neo 6 when reading about another setup (a Blackvue or Thinkware I believe) that did perform full-time surveillance.
The Neo connects to the car in identical fashion to the Nextbase hardwire kit - but its cables are a bit thicker to allow higher current charging. Fitment difficulty depends on a few things. As I already had the Nextbase hardwire kit piggy-backed onto an ignition live fuse, and the main battery and interior fusebox in my car are under the boot floor where the spare wheel ought to be, my installation was straightforward. The Neo comes with a bunch of generic output adapters in the box as well as several fuse taps. I removed the Nextbase fuse tap and fitted the Neo's version and meaty power leads in its place (same 20A ignition live fuse). I chose to sacrifice the Neo output cable with a cigarette lighter socket (I'd never use it). I simply chopped off the socket and joined its wires onto the Nextbase kit earth and live (retaining the little low-voltage protection box, although now redundant, as it is half-way along the car wherever the Halfords guy tucked it). There was just enough space next to the tyre inflator to tuck the Neo, which is about the size of a broadband hub.
If your fusebox is in the usual location underneath the dash, the Neo is small enough to site under the front passenger seat.
All this being said, to run Parking Mode Front + Rear overnight you could probably get away with a cheaper Power Bank provided you drive far enough to recharge it again.
Hope this helps.
Similar threads
