not holding charge or settings
Kris Stuart
The mini0805 that I purchased seems to be fault. When the car powers up the unit is powering up correctly but I always get a low battery warning message. When I then setup the camera (date, time, gps, switch off time etc.) it never hold the settings.
Even if I set this up then push the power button to switch the unit off with the ignition still running and power going to the camera it will not keep the settings, charge or hold any sort of power.
I have tried this with the power to the GPS and also direct to the unit but it makes no difference. Also a different power cable also does not work.
Anyone else have/had this issue?
K
Kris Stuart
Is there a way to replace it? If so where can I get a replacement battery for it?
A Mini 0805 10
R Mini 0805 4
