Attention: Commercial use is strictly prohibited! You are using my tools at your own risk! Modifying firmware will probably void your warranty. I am not responsible for anything that might happen as a result of using my tools.
Changelog:
1.1.2
Fixed a bug regarding issues with 0x0a and 0x0d bytes...
1.1:
Changed name to NtkMPE to avoid possible legal issues
Added Copy and paste functionality to table cells (CTRL+C & CTRL+V)
Improved movie parameter struct detection pattern
Added 5th column for further r&d (read only)
1.0:
Initial release
About this tool: It allows you to modify movie parameters like width, height, fps and bitrate for different modes without using a hex editor.
Usage: This tool only works with DECOMPRESSED firmware files. You need to decompress these first with bfc or a wrapper for bfc like denova or ntkautomator.
Warning: BFC and its wrappers currently only support single image firmwares. You unpack/repack multi-image firmwares, yet.
(firmware is unpacked at this stage)
1. File -> Load firmware
2. Modify the parameters (Bitrate is half of the target bitrate. Example: Target bitrate of 20mbps requires an input of 10000 (kbps)
3. Press "Apply modifications"
(4. repack and validate using tools like ntkcalc/denova/ntkautomator)
Screenshot:
Little Endian Array Utilities:
Download: http://dc.p-mc.eu/tools/novatek#ntkmpe
Changelog:
1.1.2
1.1:
1.0:
Initial release
Screenshot:
Copyright (c) 2007, intarsys consulting GmbH
Redistribution and use in source and binary forms, with or without
modification, are permitted provided that the following conditions are met:
- Redistributions of source code must retain the above copyright notice,
this list of conditions and the following disclaimer.
- Redistributions in binary form must reproduce the above copyright notice,
this list of conditions and the following disclaimer in the documentation
and/or other materials provided with the distribution.
- Neither the name of intarsys nor the names of its contributors may be used
to endorse or promote products derived from this software without specific
prior written permission.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
POSSIBILITY OF SUCH DAMAGE.
