Ocasionally missing footage
driver2
Romania
My SG9663DC is installed in a 2004 Audi A4, hardwired using the original power cable. I cut the cigarette lighter plug to connect it to a switched +12 V, as you see in the picture, in the left side. This gets 12 V for two positions of the key: one is the normal ignition, the other is a rather undocumented 'accessories', handy if I want to have the camera record at full FPS with the engine off. The fuse I used to connect to in parallel is used for the heating resistors of the windshield washer nozzles, so the circuit is quite simple: the 12 V from the battery go through the ignition switch and then through the fuse and resistors to ground. If you were wondering, the other add-a-fuse is used for a semi-hardwired GPS unit which is always powered, in parallel with the parking sensors (which I have), and tire pressure monitor and light and rain sensor (which I am not aware of). The grounding point is common for both devices and it is the screw (top right) on the metal frame which holds the dash. I actually intend to switch sometime to the silver screw from top left as grounding point.
The camera is installed since May 2018 and is currently running on FW 1.32 (updated sometime last year). I've only driven 8000 km since then. It works great, but there is still this unexplained behavior: extremely seldom (this is maybe the third time) it silently fails to write anything on the card during a segment of driving. Here is a listing of the files on the card (a 64 GB Samsung Pro Plus):
Code:
total 61176832
-rw-r--r-- 1 678980807 Dec 31 16:13 2018_1231_140857_047A.MP4
-rw-r--r-- 1 679010623 Dec 31 16:13 2018_1231_140857_048B.MP4
-rw-r--r-- 1 679033483 Dec 31 16:18 2018_1231_141357_049A.MP4
-rw-r--r-- 1 679007251 Dec 31 16:18 2018_1231_141357_050B.MP4
-rw-r--r-- 1 678946479 Dec 31 16:23 2018_1231_141857_051A.MP4
-rw-r--r-- 1 679001315 Dec 31 16:23 2018_1231_141857_052B.MP4
-rw-r--r-- 1 679044491 Dec 31 16:28 2018_1231_142357_053A.MP4
-rw-r--r-- 1 678982023 Dec 31 16:28 2018_1231_142358_054B.MP4
-rw-r--r-- 1 678909915 Dec 31 16:33 2018_1231_142857_055A.MP4
-rw-r--r-- 1 679054723 Dec 31 16:33 2018_1231_142857_056B.MP4
-rw-r--r-- 1 679075743 Dec 31 16:38 2018_1231_143357_057A.MP4
-rw-r--r-- 1 679013935 Dec 31 16:38 2018_1231_143357_058B.MP4
-rw-r--r-- 1 679044211 Dec 31 16:43 2018_1231_143857_059A.MP4
-rw-r--r-- 1 678993835 Dec 31 16:43 2018_1231_143857_060B.MP4
-rw-r--r-- 1 678966495 Dec 31 16:48 2018_1231_144357_061A.MP4
-rw-r--r-- 1 679017487 Dec 31 16:48 2018_1231_144357_062B.MP4
-rw-r--r-- 1 678965735 Dec 31 16:53 2018_1231_144857_063A.MP4
-rw-r--r-- 1 678981387 Dec 31 16:53 2018_1231_144857_064B.MP4
-rw-r--r-- 1 593584031 Dec 31 16:58 2018_1231_145357_065A.MP4
-rw-r--r-- 1 593523239 Dec 31 16:58 2018_1231_145357_066B.MP4
-rw-r--r-- 1 678909187 Dec 31 17:06 2018_1231_150119_067A.MP4
-rw-r--r-- 1 678941915 Dec 31 17:06 2018_1231_150119_068B.MP4
-rw-r--r-- 1 678961567 Dec 31 17:11 2018_1231_150620_069A.MP4
-rw-r--r-- 1 679040275 Dec 31 17:11 2018_1231_150620_070B.MP4
-rw-r--r-- 1 679076275 Dec 31 17:16 2018_1231_151120_071A.MP4
-rw-r--r-- 1 678949503 Dec 31 17:16 2018_1231_151120_072B.MP4
-rw-r--r-- 1 678688515 Dec 31 17:21 2018_1231_151620_073A.MP4
-rw-r--r-- 1 678986411 Dec 31 17:21 2018_1231_151620_074B.MP4
-rw-r--r-- 1 679180935 Dec 31 17:26 2018_1231_152120_075A.MP4
-rw-r--r-- 1 679063727 Dec 31 17:26 2018_1231_152120_076B.MP4
-rw-r--r-- 1 679007507 Dec 31 17:31 2018_1231_152620_077A.MP4
-rw-r--r-- 1 678952439 Dec 31 17:31 2018_1231_152620_078B.MP4
-rw-r--r-- 1 678985975 Dec 31 17:36 2018_1231_153120_079A.MP4
-rw-r--r-- 1 678958271 Dec 31 17:36 2018_1231_153120_080B.MP4
-rw-r--r-- 1  15224307 Dec 31 17:36 2018_1231_153620_081A.MP4
-rw-r--r-- 1  15232699 Dec 31 17:36 2018_1231_153620_082B.MP4
-rw-r--r-- 1 678897031 Dec 31 17:57 2018_1231_155205_083A.MP4
-rw-r--r-- 1 678938099 Dec 31 17:57 2018_1231_155205_084B.MP4
-rw-r--r-- 1 678962175 Dec 31 18:02 2018_1231_155707_085A.MP4
-rw-r--r-- 1 678955799 Dec 31 18:02 2018_1231_155707_086B.MP4
-rw-r--r-- 1 678956075 Dec 31 18:07 2018_1231_160207_087A.MP4
-rw-r--r-- 1 678970611 Dec 31 18:07 2018_1231_160207_088B.MP4
-rw-r--r-- 1 679171807 Dec 31 18:12 2018_1231_160707_089A.MP4
-rw-r--r-- 1 679107907 Dec 31 18:12 2018_1231_160707_090B.MP4
-rw-r--r-- 1 678910207 Dec 31 18:17 2018_1231_161207_091A.MP4
-rw-r--r-- 1 678994831 Dec 31 18:17 2018_1231_161207_092B.MP4
-rw-r--r-- 1 445916359 Dec 31 18:20 2018_1231_161707_093A.MP4
-rw-r--r-- 1 445903783 Dec 31 18:20 2018_1231_161707_094B.MP4
-rw-r--r-- 1 678945323 Jan  1 23:12 2019_0101_210744_095A.MP4
-rw-r--r-- 1 678956763 Jan  1 23:12 2019_0101_210744_096B.MP4
-rw-r--r-- 1 678959911 Jan  1 23:17 2019_0101_211245_097A.MP4
-rw-r--r-- 1 679039555 Jan  1 23:17 2019_0101_211246_098B.MP4
-rw-r--r-- 1 678927943 Jan  1 23:22 2019_0101_211743_099A.MP4
-rw-r--r-- 1 679033667 Jan  1 23:22 2019_0101_211744_100B.MP4
-rw-r--r-- 1 262320399 Jan  1 23:24 2019_0101_212243_101A.MP4
-rw-r--r-- 1 262298135 Jan  1 23:24 2019_0101_212244_102B.MP4
-rw-r--r-- 1 678977091 Jan  1 23:45 2019_0101_214039_003A.MP4
-rw-r--r-- 1 678964947 Jan  1 23:45 2019_0101_214039_004B.MP4
-rw-r--r-- 1 678986171 Jan  1 23:50 2019_0101_214540_005A.MP4
-rw-r--r-- 1 678947247 Jan  1 23:50 2019_0101_214540_006B.MP4
-rw-r--r-- 1 575470179 Jan  1 23:54 2019_0101_215040_007A.MP4
-rw-r--r-- 1 575430327 Jan  1 23:54 2019_0101_215040_008B.MP4
-rw-r--r-- 1  11479463 Jan  3 22:48 2019_0103_204804_009A.MP4
-rw-r--r-- 1  11322535 Jan  3 22:48 2019_0103_204804_010B.MP4
-rw-r--r-- 1 746519743 Jan 12 15:30 2019_0112_132537_011A.MP4
-rw-r--r-- 1 678887463 Jan 12 15:30 2019_0112_132537_012B.MP4
-rw-r--r-- 1 684133083 Jan 12 15:35 2019_0112_133031_013A.MP4
-rw-r--r-- 1 679021795 Jan 12 15:35 2019_0112_133031_014B.MP4
-rw-r--r-- 1 498077315 Jan 12 15:39 2019_0112_133531_015A.MP4
-rw-r--r-- 1 498149875 Jan 12 15:39 2019_0112_133531_016B.MP4
-rw-r--r-- 1 118901115 Jan 12 15:48 2019_0112_134718_017A.MP4
-rw-r--r-- 1 118859819 Jan 12 15:48 2019_0112_134718_018B.MP4
-rw-r--r-- 1 577887883 Jan 12 15:52 2019_0112_134821_019A.MP4
-rw-r--r-- 1 577875135 Jan 12 15:52 2019_0112_134821_020B.MP4
-rw-r--r-- 1 679868723 Jan 12 17:11 2019_0112_150613_021A.MP4
-rw-r--r-- 1 678958023 Jan 12 17:11 2019_0112_150613_022B.MP4
-rw-r--r-- 1 678429911 Jan 12 17:16 2019_0112_151115_023A.MP4
-rw-r--r-- 1 678897955 Jan 12 17:16 2019_0112_151115_024B.MP4
-rw-r--r-- 1 289385183 Jan 12 17:18 2019_0112_151617_025A.MP4
-rw-r--r-- 1 289339983 Jan 12 17:18 2019_0112_151617_026B.MP4
-rw-r--r-- 1 678924923 Jan 12 19:37 2019_0112_173252_027B.MP4
-rw-r--r-- 1 678850827 Jan 12 19:37 2019_0112_173252_028A.MP4
-rw-r--r-- 1 678956583 Jan 12 19:42 2019_0112_173754_029A.MP4
-rw-r--r-- 1 679014047 Jan 12 19:42 2019_0112_173754_030B.MP4
-rw-r--r-- 1 678989595 Jan 12 19:47 2019_0112_174255_031A.MP4
-rw-r--r-- 1 679004371 Jan 12 19:47 2019_0112_174255_032B.MP4
-rw-r--r-- 1 678972211 Jan 12 19:52 2019_0112_174755_033A.MP4
-rw-r--r-- 1 679010711 Jan 12 19:52 2019_0112_174755_034B.MP4
-rw-r--r-- 1 679091383 Jan 12 19:57 2019_0112_175255_035A.MP4
-rw-r--r-- 1 678961815 Jan 12 19:57 2019_0112_175255_036B.MP4
-rw-r--r-- 1 265032919 Jan 12 19:59 2019_0112_175755_037A.MP4
-rw-r--r-- 1 265151691 Jan 12 19:59 2019_0112_175755_038B.MP4
-rw-r--r-- 1  26227227 Jan 12 20:01 2019_0112_180053_039A.MP4
-rw-r--r-- 1  26078015 Jan 12 20:01 2019_0112_180053_040B.MP4
-rw-r--r-- 1 678910739 Jan 12 21:46 2019_0112_194119_041A.MP4
-rw-r--r-- 1 678941511 Jan 12 21:46 2019_0112_194119_042B.MP4
-rw-r--r-- 1 678997835 Jan 12 21:51 2019_0112_194619_043A.MP4
-rw-r--r-- 1 678974719 Jan 12 21:51 2019_0112_194619_044B.MP4
-rw-r--r-- 1 184655303 Jan 12 21:52 2019_0112_195119_045A.MP4
-rw-r--r-- 1 184636335 Jan 12 21:52 2019_0112_195119_046B.MP4
-rw-r--r-- 1 563485335 Jan 12 22:06 2019_0112_200208_047A.MP4
-rw-r--r-- 1 563512427 Jan 12 22:06 2019_0112_200208_048B.MP4
-rw-r--r-- 1 678940787 Jan 12 22:40 2019_0112_203502_049A.MP4
-rw-r--r-- 1 678938111 Jan 12 22:40 2019_0112_203502_050B.MP4
-rw-r--r-- 1 678958923 Jan 12 22:45 2019_0112_204004_051A.MP4
-rw-r--r-- 1 678902547 Jan 12 22:45 2019_0112_204004_052B.MP4
-rw-r--r-- 1 376514127 Jan 12 22:47 2019_0112_204504_053A.MP4
-rw-r--r-- 1 376511599 Jan 12 22:47 2019_0112_204504_054B.MP4
On the 12th of January there has been definitely one more segment between 15:16 and 17:32. The previous time this occurred was sometime in August, so it is not temperature related. Since I have the camera, I've read most of what was posted here, but I don't recall anything similar. Any thoughts?
Unfortunately, I installed the camera so that the rearview mirror covers it for me completely, specifically to avoid being distracted by the blinking red light, so I don't know whether the camera was actually powered when the hiccups occurred. I now activated the sounds so that it greets me at startup. As a side question here which I think was discussed before: can we have the option of a more discreet startup chime, something like the double beep we hear when there is no card inside?
And another side question: if you look at the filelist you will notice a two hours offset between the last modified time reported by the operating system and the time written in the filename. This is the UTC offset of the timezone I live in (EET), so obviously my OS (Linux) thinks the files are saved with UTC timestamps and converts them to my local time. It doesn't bother me, just wanted to know where the problem lies. Probably in the way Linux interprets timestamps, as far as I recall from file listings in Windows posted by others there was no offset.
Definitely leave sounds turned on so that you can listen for any startup problems since you can't see the camera
Make sure to format the card in the camera any time you've had the card out
Should also update to the latest firmware
Well, it happened again, sooner than I expected, and for this it caught me somehow unprepared. I did update to 1.37, changed settings, and formatted the card. I had a drive composed of several segments, and on the last one the camera did not record anything. I noticed the startup chime on all segments, but on the last one I can not 100% remember (this is the unpreparedness bit). It will take a while until I will notice the lack of sound.
I did not yet change the grounding point.
Ok, I will talk to the local distributor tomorrow and have them follow up with you with some further troubleshooting
