Old F770 Firmware UK
A13x
Does anyone have any download links for old thinkware firmware for f770 which is not the latest uk version? thinkware are doing the sd card blocking again
Xandros
You say 'the latest' version but that was released over a year and a half ago so if the whole "Thinkware block SD card makes/manufacturers" is actually a thing and not just a myth they certainly haven't been blocking anything since January 2018. If you have issues witha 64gb+ sized SD card in the camera, have you tried the suggestion in the other topic? Someone mentioned on a previous page they were able to fix their issues with the camera not liking their large SD card by creating a small amount of empty space at the start of the card's partition table and it supposedly worked perfectly after that. Only problem is no one's been able to confirm if that was a fluke or not and that poster hasn't been back to elaborate.
If you can't be bothered to help us determine if that's the fix or not though, I found these firmwares still available:
Those are the only versions I can find, links comes from Thinkware.com so they're legit. They don't appear to have a version .05 or .04 if you were wondering, not that I could find anyway. Note they're all for the UK version. Other regions are there too if anyone else is interested, the region code is the number before the version in the filename (f770_0_1.00.08.zip is the USA version).
A
A13x
Thanks for the links and yeah downgrading firmware allows you to use other branded cards without any issues
