thethreegs
(1) As I understand it, I need to test which side of the fuse insert shows 12 volts. I am supposed to insert the blade that is furthest from the cable into the side that shows 12 volts. Is this the correct way to install and orientate the fuse tap?
(2) Does it matter which way the new fuse and the original fuse are inserted into the fuse tap? I know the original fuse is supposed to be inserted into the slot nearest the blades but does it matter which way it goes in?
(3) What are the most common fuses to use for continuous power and only when turned on? Only turned on, should I use the cigarette lighter and continuous use an interior light? I have a 2014 Hyundai Elantra GT for reference, if that even matters.
