old4570
- Jun 11, 2015
- Australia
- Front: 70MAI , Ausdom A261, Mini 0826 , Rear: A118c
Video information for the mirror cam
Video information for the rear cam
Product Link
Youtube Video
First Impression :
I have never used a mirror cam before and have always wondered . My car has to many cams to the left of the mirror ( camera is located on the left side of this mirror cam ) so I had to put it in my brothers car . Instillation was very easy , especially as the rear cam is powered from the mirror cam . Should you chose to activate / make active the reversing cam , you will need to tap into the reversing lights . Speaking of the rear cam , in normal use it is 480 resolution , it might revert to 720 when you use the cam as a reversing cam , but for normal use it is 480 . So , painless to install and the menu is very simple and easy to set up . I might have to say possibly one of the easiest cams I have set up . Now it actually looks like there might be GPS ? , I will have to try a GPS antenna / receiver and see if there actually is a functioning GPS . That will be latter .
Using the cam :
Once again very un challenging , I was a little surprised at just smoothly the install went . The rear cam particularly , just plug it in and route the cable to the back and use some double sided tape to fit the cam to the rear window . ( Sounds too easy - it actually was just that easy ) . There was plenty of cable , and if anything perhaps a little too much . ( Perhaps not as there are larger cars out there / vans / station wagons )
If you like you can have the video show on the mirror constantly or have it turn off ( video output ) so as not to bother you . Now I left it on to see just how much it might bother / distract . Nada - Nothing ! ( During the day ) . The video image vanishes as you drive and is barely noticeable as you drive and watch the traffic behind you . To see the video image in the mirror you really need to concentrate hard . So during the day , it was neither here nor there for me .
Installing and removing the micro SD card was not hard at all . Even with my short fingernails I was able to install and remove it . I would how ever have liked for the card to protrude ever so slightly for even easier insertion and removal . Maybe if the card stuck out 2mm it would make removal and insertion easy even for people with dexterity problems . ( Old people )
Video Quality :
With the resolution @ 2304 x 1296 and the bit rate at 8000kbs , I think the video is a good compromise for size VS quality . Though I can not help feel that this cam much like so many others I have tested is not focused quite at the sweet spot . ( To me it seems focused a little too close to the cam - near focus ) I would have liked to have seen the lens focused for infinity ( Focused further out ) . This is something I have seen with a lot of cams regardless of price and might be a case of pot luck . ( I may need to play to see if I can't improve the focus ) Now my brother does already run a mirror cam that is 1080 ( FHD ) and the video quality on the Oumax RV55HD-M is better than that of my brothers cam .
The rear cam @ 480 is a little disappointing but functional . ( Watch the video ) For some strange reason the rear cam is reversed making it look like I am driving in America (?)
Audio Quality :
I was pleasantly surprised , the audio is good ! Nothing worse than having a decent cam with bad audio , such is not the case here and the audio is good . Again I recommend watching the included video sample .
So Far :
Really easy to set up , no problems . Rear cam was easy to set up . Removing the Micro SD card is relatively easy . I will have to take it for a night time drive as well see if the cam actually has a functioning GPS . As well I will have to play with re-focusing the cam and see if I can improve the video quality . I would say the RV55HD is probably ideal for countries with left hand drive , here in Australia we are right side drive so it would have been better if the lens was located on the right side of the mirror cam . Over all I would have to say this is a well thought out package . I would have liked to have seen a higher resolution rear camera and better focus on the front cam and have the micro SD card protruding ever so slightly for even easier insertion and removal . Other than this , the Oumax RV55HD-M is pretty damned good .
So ends part A . ( Be back with part B )
