I messed up the alignment of the A129, which is different. The A129 is still a little bit better with license plate reading, but the new cam is working like it should be (the right car was moving).
Still hoping for a good A139 Pro offer, some day
BTW: The GPS Sensor of the A229 really sucks, it takes forever to find a satellite and look at the speed text in the screencaps, - A129 -> 0 km/h; A229 still going down from 50 km/h
Just check these two images out @viofo , @VIOFO-Support
Was this one working normal too?Your A229 is performing as advertised.
Are they?Your expectations of the A229 are unreasonable.
-Chuck
Here Sir, I compare it with A129. See the images quoted above. Same exact issue which I face.No need to compare the A229 with the A119 line, compare it with the A129.
Here is the footage:Grab some footage and contact the support,
Does the replacement one able to read plates at night while stationary? Check the videos above. You'll get an idea of what I am saying. Mine are not even LED or HIDs. They are stock halogens.my unit was replaced because the focus wasn't right and the image at night (especially with modern led light) was rubbish. The replacement unit was much better.
Maybe I don’t understand something, but why does HDR appear on the video?Here is the footage:
Does yours too performs this awfully at night?
In the shot the dominates sky over the horizon, this impairs proper exposure of what we are interested in on the road and surroundings. Personally, I would recommend pointing the camera lower so that the sky is less than halfway through the frame. And even though the hood and dashboard will be at the bottom of the imageHey,
I ordered my A229 in June and using it since July. My prior Dashcam was a A129 Plus (the first model). I mainly ordered the camera because of the thin cable for the rear dashcam and of course the better video quality / higher resolution.
So far in this thread I haven't found any mention of how the bitrate is set ?Sunny weather might be a problem at the moment, but I'll keep that in mind and a brick building shouldn't be a problem to find.
Isn't this setting in the menu?So far in this thread I haven't found any mention of how the bitrate is set ?
As far as I remember, highest settings. The cam is already sold months agoSo far in this thread I haven't found any mention of how the bitrate is set ?
I have some really bad quality footage from this dashcam. Sometimes you can't even read big signs. Updated to the lasted FW. I had this issue since the beginning but I thought it may be a FW issue.
The camera has problems focusing.I have some really bad quality footage from this dashcam. Sometimes you can't even read big signs. Updated to the lasted FW. I had this issue since the beginning but I thought it may be a FW issue.
