Parking Mode Audio?
A13x
Hi has anyone managed to get the F770 to go into parking mode as mine seems to remain on constantly recording. I was wondering if/when i cut the ignition is there supposed to be some audio from the device to say it is going into parking mode or does it just happen without any audio?
Yes there will be a voice that says Parking Mode is now starting.
Check your ACC wire and its power source.
As said it tells you that it's now entering parking mode, between 38 and 42 seconds from losing ACC supply, mine works perfect, check parking mode has not been turned off in settings as it does allow this.
Depending on what car you have and more specifically where you picked up the ACC wire the circuit may be controlled by a BCMm body controlled module this can keep certain circuits live for up to 1 HOUR after turning off, normally things like interior lights fag lighters etc,
Thanks, i managed to get it working
