Parking mode - G-Sensor
Sergiosmvc
Portugal
Hello
I have one A129 Duo hardwired with HK3.
I liked more low bit rate parking mode.
It is possible with low bit rate parking mode use also G-Sensor?
I want that because if i someone hit my car and if in that day i miss it or forget to check for any damage on my car tomorrow can be late.
If the dashcam used the G-Sensor that footage was protected.
Nigel
Devon
Gitup F1, A129, B1W, B2W
Yes, the G-sensor should lock the low bitrate files and put them safely in the RO folder.
S
Sergiosmvc
Portugal
Hello,
I set the g-sensor sensitivity to High.
I tried to simulate some impacts to trigger the G-Sensor but i don't know if that was triggered or not because there isn't an RO folder.
I tried with Time-lapse and low bit rate but it didn't work.
if another car touch my car and scratch it, should G-Sensor be triggered?
Regal
Germany
... if another car touch my car and scratch it, should G-Sensor be triggered?
It could be but there is no guarante that the G-Sensor will get triggered.
It depends on how hard the impact is. You should be able to trigger the G-Sensor by closing your car door in a very hard way but at the same time there can be another car which touches your car during a parking maneuver and the G-Sensor won't recognize.
SawMaster
SC
G1W-S, G1W-HC, G1W clone, B1W, K2S, B2W, (ex N2Pro & Mobius)
There is some variation in all G-sensors, even in the exact same cams. There is a LOT of variation in them across all the different dashcams. None are absolutely reliable in every situation and there's not much you can do if yours doesn't make you happy.
S
Sergiosmvc
Portugal
It that case i think the more secure is low bit rate recording parking mode.
