Hello,
This is my first post. I'm glad to meet all of you . I hope you can answer a few questions for me . I purchased the Street Guardian SG9663DC and hardwire harness SGDCHW a week ago and installed it in my 2018 Honda Civic Hatchback. The install is very clean , a few tips from others routing the rear camera cable was a big help . I was able to fish it through the rubber conduit between the hatch and the body for a no leak factory install. I have the parking mode time set to 5 minutes and the battery cut out on the harness set to 12.4. I would like to purchase the Cellink Neo for parking mode leaving the starting battery out of it . My questions apply to the output side of the Cellink and the 3 wire dyi harness supplied with it and the SGDCHW harness . Are the outputs internally fused or should a 5 amp fuse be installed in the acc and bat wires coming right out of the Neo to protect the camera wiring ? If I were to set the voltage protector to its lowest 11.8 and the camera timer to 24 hrs what will happen ? Will the Neo be turned off when it hits 11.8 or will the camera timer override the cut off ? The camera harness cut off device brings the 12v down to 5v out and also regulates the battery state of charge for cut out . Is this regulator in line not going to allow the Neo to get to say 9v keeping the 5v cameras running? What is a low voltage for the Neo ? Will I need a different 5v out with no battery cut out ? Thanks for your thoughts . Happy New Year!!!
