Agreed. I have both the SG dc pro and the a129 pro... Learning a lot of differences...... But definitely needs a timer for parking mode.
@viofo if not done already for the beta or upcoming firmware can we get a power button functions for 3 wire mode ? IE. Parkin secure garage, don't need parking mode, don't want to unplug it all the time, Press and hold the middle button for 2-3 seconds to shut it off. as well as the timer function
To calculate the exact amount of time the camera will run before draining your car battery, you should consider a wide range of variables (battery capacity, battery state, recording frame rate, etc.).
I've never tested it by myself but, from what i've learned reading this forum, leaving your camera recording for 2 or 3 days isn't really safe. You are going to discharge your battery completely or shortening its life.
Unless you use a 3-wire kit...
You have a voltage cutoff on the 3 wire hardwire kit. I run 12.2 on mine. It's about the lowest you want to go. 12.4 is very fickle, as unless you have a new battery, the camera will be cut off rather quickly. 12.2 would be recommended for MOST if not all people.
