I would like to install a dash cam primary to have a recording in case there is an accident.
I would like 2 channel, discrete (no screen), wifi, automatic switching to parking mode and all other goodies so that I could install it and forget about it.
I would also like it to record when the car is parked. Not that I am in a feud with a neighbor , but I park on the street in a city so it might be helpful.
So I started reading about possible solution (motion or radar detectors, G sensors, 1 frame per second recording, etc) and I realize that in my situation I won't be getting a full use of it.
Ideally I would like the camera in parking mode to activate when a person someone is approaching the car from any direction but not to be triggered by a passing car (since that would mean constant recording).
I have the following questions:
1. Motion or radar detectors: the car is parked on a busy street. Will every passing car set off the motion detector? In which case the camera will be recording all the time. Will someone walking on the sidewalk next to a car trigger the recording? If I set the sensitivity to 'low' - can it miss someone scratching the car?
2. How will it behave in a parking lot? Will every passing person or a car trigger the motion detector?
3. I am thinking about either setting it to make pictures every second - will that use much less power? Will it capture a license plate if someone hits my parked car at night?
4. In any case, how long will the camera be powered before the main battery goes below 12.4 v it shuts down?
If it is going to record even for 3-4 hours - that would cover me in parking lot and covering first 4 hours parking on the street - should be good enough for me since I really don't want to spend extra 300-400 on an external battery.
Another problem with external battery is that very often I don't drive for a week (except moving the car for street cleaning twice a week) and even the Cellink battery won't provide enough power to last that long. Moving the car for street cleaning (5-10 minute drive) will be enough to charge the main battery , but not enough to fully charge the external one.
So what is my optimal solution? Should I just use the main battery and let it record for several hours until it shuts down?
Or should I still invest in the external battery and let it record for 2-3 days?
As for the dashcam looks like Thinkware F880 Pro has everything I need.
Any other suggestions?
Thanks.
Thanks.
