Parking mode
schiacciato
Ireland
PM you already
Hi,
After hardwiring and testing the auto-parking mode, I can confirm it is working perfectly well.
Can I ask @estore009 to also send me link to the auto-parking software with Wifi default OFF, please? I want parking mode to last longer than it currently does.
Thank you very much
estore009
Retailer
Shenzhen
China
B1W/B2W/Mini0906/DV688/B1M/DV988
Can you please send me 20180614s auto parking mode firmware - default WIFI ON and default WIFI OFF?
If you hardwired B1W, please load 20180614s auto parking mode firmware! And PM you download link already, please check!
My b1w has constant power from car charger. I have test that locking the car and leaving it over one hour and after that i was still able to connect with camera. Can I use auto parking mode firmware without hardware kit?
Suggest that you use a hardwire kit for dashcam, it can help you to avoid battery drain. And also, PM you firmware download link already, please check your inbox message!
estore009
Retailer
Shenzhen
China
Hi,
Thank you very much
PM you already!
maxtlab
Uzbekistan
Hello guys. Great cam, I want to try new firmware with parking mode and WIFI on. @estore009, please PM me.
Gman71
Hi. i Just bought this cam and I'd also like to try the new firmware 20180614s auto parking mode - default WIFI ON and default WIFI OFF. @estore009, please can you PM me.
golgeoyunu
Turkey
Hi, Can you send me the new firmwares about automaticly switching to parking mode, thank you !
estore009
Retailer
Shenzhen
China
Yes, PM you already!
PM you already, please check your inbox message
Gman71
@estore009 - thank you for the link for the Auto parking firmware.
I have two questions about how to install the firmware as I do not want to brick my B1W in the process.
The User manual section referring to "Firmware Update Instructions" mentions 2 files
- cardvr_img.bin
- default_cfg.bin
The link you provided to me only seems to contain 1 file - 'cardvr_img.bin'
1 - Do I need the other file to upgrade my firmware?
2 - Do I just format the microSD card then copy across the file 'cardvr_img.bin' then insert card and turn on the camera?
I am currently on firmware version '20180528s wifi default off'
Thanks for any guidance you can give
rick099
It has been rare to get such prompt & direct service from chinese sellers ie ebay ,Ali etc
you are a breath of fresh air estore009 , well done Vicky :love:, I joined y/day & you fixed my problem inside 6hrs
whats the opinion on using a 10000m/a powerbank for parking ??
estore009
Retailer
Shenzhen
China
It should work with your powerbank, make sure its output 1.5v 0.5a to the camera
jysl
estore009
Retailer
Shenzhen
China
Yes, please check your inbox message!
coolVariable
Hello estore009.
Could you please also send me your custom firmware?
Thank you
tekapi
Hello @estore009
I would also like the auto parking mode firmware update!
Just got it from amazon and have hardwired it.
coolVariable
There does not seem to be much difference in power consumption between parked mode and recording mode.
Both hover around 5.12v to 5.14v and 0.30A to 0.34A. It seems to be mostly around 5.12V/0.32A.
(Using a USB voltage and amp tester between the charger and the dashcam)
gokhan
Turkey
Hello @estore009
