Midium level pleaseIf you have big car like van or you parking on windy place (close or between buildings too) it can be reason. How is your G-sensor configured? medium or low?
PMed you already, please check!Currently running on v1.06.180528s, pm the new firmware please
Yes, please check your inbox message, thank you!Could you please PM me the auto parking mode firmware
Yes, this is the standard operation with the firmware 20180528s
Yes, it is!
And you can load the 20180614s firmware
PM you this double-click firmware already, please check your inbox message, thanks!@estore009
Can you send me the double tap firmware?
I tried the auto one, but I have some issues with the auto parking mode (even on a standstill table in the home, or hardwired în my car it turns to park after many hours or not at all)
Thank you!
I was still testing the auto parking mode so it was left on a dining room table overnight with no movement or air movement. I did this for a couple of days but it always records for around half the time it’s left on. The G-sensor is set to the recommended medium setting.If you have big car like van or you parking on windy place (close or between buildings too) it can be reason. How is your G-sensor configured? medium or low?
No, but nothing was moving in the room and the dash cam wasn’t moved. I thought auto parking mode just used the G-sensor to record for 30s when the dash cam felt movement? If left for 5 hours there was always around half the time recordings were made...did you cover the lens?
Might be triggered by G-sensor impact and other unsure factors, such as light conditions around the camera!No, but nothing was moving in the room and the dash cam wasn’t moved. I thought auto parking mode just used the G-sensor to record for 30s when the dash cam felt movement? If left for 5 hours there was always around half the time recordings were made...
We disable motion detection at default for our cameras, and users cannot do configuration for its motion detection!does it use motion detect?
if motion detect is not used then light shouldn't affect it, if you were using motion detect then changes in lighting will trigger a recordingWe disable motion detection at default for our cameras, and users cannot do configuration for its motion detection!
Will double check this point!if motion detect is not used then light shouldn't affect it, if you were using motion detect then changes in lighting will trigger a recording
PM you already!Can you please send me the new firmware for automatic parking mode with wifi on?
Some tester feedback me it is not stable, so...What happened to the low FPS parking mode firmware? Is it still available?
M | Parking mode issue | B1W | 4 | |
T | B1W: Parking mode wiring help needed please | B1W | 1 | |
J | Looking for a firmware with the iOS fix and parking mode | B1W | 2 | |
S | Parking mode? | B1W | 2 | |
C | Parking mode and battery pack | B1W | 5 |
