Thank you very much, I will try it soon and tell you my experience.
Thank you
Could you provide me with a copy of this new Firmware? Thank you
Goodnight,
I have tested the camera with the firmware that double click enters into parking mode and I think everything is correct.
I have not tested the original firmware, so I can not say if it records better or worse but if I have two doubts in the operation that call my attention:
1ª.- When the camera is recording, if the button is pressed and it is not released to enter wifi mode, in many cases the camera keeps the video in progress and should not do so since the button is not released, it is not of a rapid pulsation.
2 .- I have the G-sensor configured in high mode and after making my first trip (1.5 hours) I expected to have blocked some video but it has not happened. I've driven by county road and motorways, I've gone through some potholes, roundabouts, speed bumps, I've taken the garage ramp, etc and nothing, not a single file in the folder \ EVENT \ event_rec.
I have to say that if I tap the camera with my finger while it is graining, it blocks the video, but it has not happened to me driving and I repeat, I have it set to high mode. How can I test if the G-Sensor works correctly, How can I verify that it is well calibrated?
Thank you
___________________________________
Buenas noches,
He probado la cámara con el firmware que haciendo doble click entra en modo parking y creo que todo es correcto.
No he probado el firmware original, así que no puedo decir si graba mejor o peor pero si tengo dos dudas en el funcionamiento que me llaman la atención:
1ª.- Cuando la cámara se encuentra grabando, si se pulsa el botón y no se suelta para entrar en modo wifi, en muchas ocasiones la cámara guarda el video en curso y no debería hacerlo ya que no se suelta el botón, no se trata de una pulsación rápida.
2ª.- Tengo configurado el G-sensor en modo alto y después de realizar mi primer viaje (1,5 horas) esperaba que hubiese bloqueado algún que otro video pero no ha ocurrido. He conducido por carretera comarcal y por autopistas, he pasado por algunos baches, rotondas, badenes, he tomado la rampa del garaje, etc y nada, ni un solo fichero en la carpeta \EVENT\event_rec.
He de decir que si le doy un golpecito a la cámara con el dedo mientras está granbando, bloquea el video, pero no me ha ocurrido conduciendo y repito, lo tengo configurado en modo alto ¿Como puedo probar si el G-Sensor funciona corectamente, cómo puedo comprobar que está bien calibrado?
Gracias
