RockyRay
Hi everyone
I am a total novice to dash cams as never had one before so not sure what they can/cannot do so any help would be appreciated.
Background - I am a milkman using a van through the night and very often stop and start turning the ignition off, so often parked at side of road for a few minutes
while I deliver.
Looking at getting a Nextbase Dash cam and hard wiring to fuse box ( this I know how to do) but I want it to record while I'm parked up as well as when driving...Is this possible
with ignition off, guessing a permanent live ? It'll be basically recording 24/7 then won't it ?? So guess it will drain battery very quickly.
What can I do, can it be wired to something else ? Is there settings that allow a Dash cam to continue to record after switch off for 2/3 mins then start back up properly
when ignition is turned on.
Any help to this novice would be very helpful
Thank you
while I deliver.
Thank you
