Error7
- Apr 15, 2014
- Kearsley, Bolton, Manchester
- United Kingdom
- Mobius - 808 #16 4 x G1W-H - 2 x 70mai
Yesterday I needed to use the Playback Mode on my Mobius but I couldn't get it to work. It worked for me on one occasion about 12 months ago, so I began to wonder if a firmware update had changed the way the Playback Mode functions. I did a search on this forum for 'Playback Mode' in case I had missed a revision of the instructions but I didn't find anything relevant.
So I checked to ensure that I was following the instructions properly, I was, so I then installed the oldest firmware I could access, 1.13. This made no difference. So I then started to push buttons in a fairly methodical manner until I arrived at a combination that allowed me to access Playback Mode and review footage I had previously recorded.
This is the combination I came up with:
1. Turn on the camera if it is not already turned on then wait for YELLOW LED to start flashing.
2. Press the Shutter button - LED will change to steady YELLOW
3. Press the Mode button - LED will change to steady BLUE
4. Press the Mode button again - LED will change to steady RED
5. Press the Mode button again - camera will enter playback mode
6. Press the Mode button again - the first frame of the first clip found on the card will show on the external monitor.
Press the Shutter button to play or pause the clip.
Press the Mode button to advance to the next clip.
Press the Power button to exit Playback Mode and turn off the camera.
I also discovered that when using this combination of button presses with Firmware 1.13, the monitor displayed NO FILES, even though the card was full of .MOV files so I re-installed 2.37 and was able to see all the files on my card.
