Please help with a firmware update
gkm24
Winchester
I am trying to update my 312GW. What am I doing wrong? I have downloaded the firmware update, unzipped it onto an SD
card and inserted it and it will not update, it just says to format the card. I have tried to connect it to the app and it can't find an update. The version on the cam is R06.9 and the new version is apparently 6.4. I only bought the cam last week so it should not have a fault. Any help greatly accepted.
Kremmen
West London & Reading
      Viofo A119 V2 Viofo A119 V3
Step 1, check you do have a 312 as this model is quite old now. The latest version for some years now is the 322.
If it is a 312 then unzip the file (as you have) and make sure the capitalisation is right as exactly "FW96655A.bin"
Format a small SDCard (32GB or under) to FAT32 and copy the file to the card then card to the 312.
Do not plug the cam into a PC USB but use either the car USB or an interior house USB or mains mobile phone charger using the Nextbase included PC USB cable.
NextBase Support
Caerphilly
Nextbase
Hi there,
You may find two versions of the reported firmware as there were two variants of the 312GW produced, both R06.9 and R06.4 are the latest version of firmware for both.
No update will be required for your camera if this is running either of these versions.
Regards,
Dan - Nextbase Tech Support
Schwarzwaldelch
Europe
Germany
This happend to me too. I formatted the sd-card with the 312GW, then I put the card in the PC and deletet the two files and copied the firmware-files onto the card.
After inserting the card I plugged the cable into the charger and the firmware was updated.
But you don't need to update!
Regards
C 312GW 4
J 312GW 7
