High!
I just bought a great little Mobius cam and for the first time entered this forum.
The Mobius cam can be perfectly used to "guard" my car when it is parked. For that purpose I need maximum recording time, like at least 12 hours, but preferrably more. I tried a 32 GB micro SD card and have set the Mobius to 1280x720, 30fps, 5 min video clip length, and low video data rate. Result: It creates 5 minute clips of app. 225MB each and the bitrate is around 5.700Kbps. This means that a maximum of app. 11 hours can be recorded. Despite the "low quality setting" picture quality is not too bad.
I also tried the following setting: 1920x1080, 30fps, 5 min video clip length, low video rate. This produces 5 minute clips of app. 458MB each and the bitrate is around 12.000 Kbps. These results mean that a max. of app. 5,5 hours can be recorded. Picture quality is quite amazing.
The next step I've tried is to reduce the fps rate from 30 to 12 by using the trick with the SYSCFG.TXT file (ASCII), thus manipulating the firmware. I'm not a programming expert, but this trick is not too difficult to understand. I wanted to try a 12 fps setting because I have experience with a little HD cam that produces only 9 fps clips and "the movements" in these clips are of a quite exceptable quality. Changing from 30 fps to 12 fps made me expect the bitrate to go down from 12.000 Kbps to 12/30 x 12.000 = 4.800 Kbps and the max. recording time to go from app. 5.5 hours to app. 13.8 hours while still having 1920x1080 picture quality.
Unfortunately it appeared that the cam does not take the 12fps firmware change input.....
Anybody knows if and how it is possible to change the fps rate?
Thanks for your comments.
