Power cable issues?
MiriV
Good day everyone,
Has anyone else encountered issues with their power cable? I believe mine is faulty (cuts off randomly, cuts off when I move the cable etc.). It worked fine for about half a year and now I'm having issues. I pulled off my a-pillar to see if I pinched it somewhere, but it looks fine and the issue seems to be with the wire part right by the cigarette plug.
I see SG has replacement cables available, wondering if there is a 3rd party option that is of better quality before I pull the trigger. Camera itself works great.
Not common with the new updated power supplies but still possible.
The biggest problem is when people try to insert/remove the plug with the DashCam already mounted. Best to only insert / remove with the DashCam off the mount first.
You have a 2 year warranty. Send us a support email or private message here with your details if a replacement is needed.
I cant say i have heard of this.
Do you think its at the plug in the camera, or maybe along the wire ?
I am more inclined to think its a PSU issue, do the screen flicker or do it just go on and off.
Just saw "seems to be with the wire part right by the cigarette plug " so probably a PSU issue, MSG jon and he will have a fresh one heading your way ASAP
Can you clarify what you think the actual issue is? Are you hardwired (snipped off the cigarette lighter adapter? Or what?
I think he are using power wire as is, but there seem to be a issue on the lighter plug or the wire right behind it.
P SGGCX2 1
kandrey89 SGGCX2 6
Brent. SGGCX2 21
