Power drain on car Battery
Probably 24 hours although I use the car every couple of days for about a 30 min drive
Anything more than 3 Hours you're going to need an auxillary power source.
Generally speaking hardwiring a dash cam to a vehicle starter battery through the fuse box is only going to provide 3 Hours of parking mode before low voltage cut-off happens to prevent from killing the battery to the point of a no-start when you return.
And that's with a daily commute charging the battery everyday.
Long story short, you need a dash cam battery pack, or similar.
Trying to get 24 Hours of parking mode from your vehicle starter battery ain't going to happen.
In some cases large vehicles, or diesel engine vehicles with huge stater batteries can get 12-24 hours of parking mode.
But it sounds like you have a modern small engine car with "sensitive" battery & electrical system.
Expensive compared to an obd cable with the VO04 voltage cut out switch that can be set to 12.4v at 25 euros
That's only going to provide 1-3 Hours of parking mode coverage not 24 like you require.
Expensive
It's only expensive to those who don't understand it's "value".
Frank Sinatra said this about Dean Martin;
"Always expensive, and always a bargain" šŸ„ƒšŸøšŸ„‚šŸ¾
Let us know how the OBD2 Power Cable goes.
What about using this as a solution. Plug it in at night only
UGREEN Nexode 45W Power Bank 20000mAh External Battery Portable Quick​
Won't work I believe as capacity isn't enough, would require pass thru charging etc etc
Sorry but could you explain that in more detail please. I need an idiots guide please so I can understand how it works better
I wonder if the listing is mixing up the terminologies of two-way charging and pass-thru charging?
Would you not be better getting an actual dashcam battery pack that uses the safer LiFePO4 batteries, maybe something like the Viofo BP60 that can be charged up in your house when the days are particularly hot?
At 3 times the cost of the actual dash cam cost?
I dont think so
Could be cheaper than replacing a burnt out car though... šŸ˜€
Sorry I really do not understand your point I am unplugging the dash cam power source from the car battery and plugging in the UGREEN Nexode 45W Power Bank 20000mAh External Battery . It's not connected to the car in anyway shape or form so please what is the fire hazard?
Not Safe to be left unattended in car: Lithium-Ion
Not Safe to be left unattended in car: Lithium Polymer
Safe to be left unattended in car: Lithium Iron Phosphate (LiFePO4)
Yes, this statement is largely true in terms of relative safety, though it is an oversimplification.
  • Lithium-Ion (such as NMC/LCO): Often found in phones, laptops, and electric bikes. They have higher energy density but use metal-oxide chemistries that break down at lower temperatures (around 150°C–210°C) and release oxygen when failing, which can fuel intense thermal runaway fires.
  • Lithium Polymer (LiPo): A variation of lithium-ion technology using a flexible polymer electrolyte instead of a liquid one. They are lightweight and power RC drones, hobby gear, and slim gadgets, but they are physically delicate, easily punctured, and prone to swelling or violent fires if mishandled or overcharged.
  • Lithium Iron Phosphate (LiFePO4 / LFP): Technically a subset of lithium-ion, but chemically and structurally different. They feature a strong olivine crystal structure with covalent phosphorus-oxygen bonds that do not release oxygen during decomposition. Their thermal runaway threshold is much higher (around 270°C), making them vastly more stable and resistant to fire or explosion under stress, overcharging, or physical damage.
Important Nuances to Keep in Mind
  • LiFePO4 is still a lithium battery: While much safer, they are not completely immune to failure or misuse. Poor installations, bypassed protection systems, or charging below 0°C without proper cutoffs can still cause damage or vent hazardous gases.
    Reddit +3
  • A Battery Management System (BMS) is essential: Regardless of chemistry, a working BMS is required to monitor voltage, current, and temperature to keep the battery operating safely.
If you are planning a project, let me know:
  • What device or system you are planning to power
  • Whether it needs to be indoor, portable, or vehicle/solar-mounted
I can help you choose the right setup.
AI responses may include mistakes. Learn more
Connecting this to your previous question about safety, the UGREEN Nexode 45W 20000mAh Power Bank uses a Lithium Polymer (LiPo) battery chemistry.
While you highlighted LiPo as "Not Safe" in your previous scale, it is the standard choice for modern high-end portable chargers like this one for specific engineering reasons.
Why UGREEN Uses Lithium Polymer
  • Form Factor & Weight: LiPo chemistry allows UGREEN to shape the battery cells into a flat, compact footprint that weighs 468 grams. A LiFePO4 battery with the same 20,000mAh capacity would be roughly twice as large and heavy, making it impractical as a pocketable "airplane-friendly" charger.
    Amazon +1
  • High Power Output: To achieve a 45W fast-charging output capable of powering a MacBook Air or rapidly charging a Galaxy Ultra/iPhone, the cells must handle high current discharge. LiPo handles these rapid power transfers efficiently in tiny sizes.
    Amazon +1
How UGREEN Offsets the Safety Risks
Portable charger manufacturers know that consumer electronics take a beating. To make a Lithium Polymer battery "safe" for air travel and daily use, UGREEN implements several multi-layered protection layers:
  • ThermalGuard System: It uses built-in temperature sensors to constantly monitor heat levels. If the power bank gets too hot while fast-charging your laptop, the system automatically dials down the wattage to prevent overheating.
  • BMS (Battery Management System): The internal hardware actively prevents the specific triggers that cause LiPo failures—safeguarding against overcharging, over-discharging, short circuits, and power surges
Okay thanks I'll just scrap the dash cam as a waste of money and not fit for purpose
What about this
VANTRUE USB C Wired OBD Display with 3 Levels for All Vantrue Cameras, Low Voltage Protection 11.6V/12V/12.4V, 23.6V/24V/24.4V, 24 Hour Parking Monitoring, 3 Meters. And disconnecting my existing hard wired system​
Quick update Vantrue sent me this in an email
''For the ACC hardware kit, you can purchase the VP01 or VP05 models; both include a 12.4V setting.
For OBD cable, you can purchase VP04.
Of course, using an external outdoor power supply is the best option. Its battery life is much longer than that of a car battery. For example, products such as DJI, Anker, and ECOFLOW are available''.
My dash cam did not have those items included when I purchased the dash cam, but there is also no warning that anything less than a 12.4 V cut off could result in a continuous battery drain.
However it does not address the issue with modern Mild Hybrid car engines and the computer systems that shut down with any continuous battery use after the car is switched off.
I am now beginning to think that dash cams are not fit for the purpose of overnight parking monitoring with modern car engine designs
Just an update I contacted Vantrue direct and am still in contact with them, but it appears they did not inform me of the fact that the kit I purchased was not compatible with the newer MHEV engines. It appears to me that they have mis sold this particular kit to me, without any warning of the compatibility issue, but it could be solved had they supplied the VP04 hardwired kit
As my installer is no longer available I feel Vantrue should supply me with the correct OBD kit and then at least I know there will no longer be an issue of my battery draining overnight.
I will keep you all updated
Vantrue have agreed that the original hard wired kit is not compatible with my modern MHEV car engine battery management system and have offered to sent me a free of charge OBD kit with the voltage shut off available at 12.4V.
I know from above that this will not resolve the overnight parking issue but at least it will stay active for a few hours after parking and at least cover the period of most activity at night on my street.
And not flatten my car battery.
Thank you Vantrue good customer service
Result.
