Power drain on car Battery
So now they have changed it all I have to order the cable from the Vantrue store on AliExpress as that is where I made the original purchase, pay for it then claim it back, however the Vantrue store are saying that unless I provide them with video evidence of the issue (how can I provide video evidence of an invisible battery drain is beyond my comprehension)
I have given up and purchased the cable direct from Amazon.es and it will be delivered today.
I have also completed a scathing trustpilot review
Never purchase from these companies again
OBD VP04 kit installed and all working as it should, just a shame Vantrue could not supply me with the cable as a gesture of goodwill, however i will pursue the matter as I feel I was mis sold the original VP03 kit as it never gave any warning that there could be conflict between my modern Seat Leon MHEV and Venture's VP03 kit, had they warned me of the possibility I would have reviewed my order and changed it to the correct one, and saved myself 3 flat battery mornings.
Not very happy with Vantrue
I know I have probably bored you all with my issues but once again the VP04 kit does not work due to the complicated engine management system of my modern MHEV car, as the onboard computers stay activated with something plugged into the OBD port.
Back to square one lol
Not picking sides here, nor defending anyone...but this is not necessarily a Vantrue issue. Brand (Vantrue, Viofo, etc.) specific hardwire kits tend to be universal in nature for the bulk of the automobiles on the market, and they work well. It is a bit of a stretch for the manufacturer of HK kits and OBD II adapters to design for each specific brand and style of hybrid autos. I would say to return that HW kit to Amazon and get a refund.
What fuse numbers and names are you using? Looking at the Seat for 2021 to 2026, I see a number of fuses for trailer, 12v socket, starter motor, etc. You may need to ask the dealership if they can recommend fuse locations.
Looks like #13 Central Locking is constant power. Fuse 23 (vacant) and 52 (12vSocket) are probably ACC power.
I was thinking similar that it could be the actual fuses being used. As I might be changing to a hybrid soon, I'm watching with interest because I want to make sure my BP100 will work.
It's attached to the correct fuse, and whilst I agree with what you say, manufacturers should at least give a warning to customers to check compatibility issues with any modern hybrid car, if they had issued that warning I would have carried out further enquiries to ensure what has happened in my case would not have happened, but no warning was issued, so it is in my opinion it is a vantrue issue of mis-selling a product and not issuing a warning.
I understand that cost is a consideration, but perhaps think about adding an external battery pack with a Cig Lighter adapter to best divorce the car's electrical system from the camera. Some car's don't have the Cig lighter adapter which can be an issue. The costs have come down for these dashcam dedicated battery packs.
Find an online forum for the car you are considering and do a search; chances are good someone there has already found a solution to the problem and has posted it. A lot of the model-specific forums have factory-trained mechanics there that will answer questions. I use the subaruoutback.org forum for a lot of information. There is a wealth of knowledge in those car forums.
I have tried that but no success. I am wondering if a dedicated solar panel charger would overcome the draining issue with the car. It would have to be fitted to the battery positive terminal then to a earth point and not the negative terminal, along with the dash cam set to collision only mode in parked at level two which hardly uses any battery drain
Fuse? Should it not be connected to two fuses?
Could I ask what exactly it is about your car that prevents a battery protect being used for the dashcam?
Sorry not sure what you mean about fuses. As for the battery the voltage cut off should be 12.4 v and the car intelligent BMS cuts power at that point to save the battery charge, but my supplied hard wired kit is only set to 12.0v so the car 12v battery is drained below it's safety level. However as 9 am not an expert in modern MHEV engines and electrical systems I really don't have much understand, save to say my sophisticated car management systems is something is connected to its power supply and therefore does not switch into any eep mode.
It was so much more simply with an old conventional car but today wow
I think it would depend on the Battery Management System, modern VAG MHEV cars have two batteries one 48v to run all the complicated electronics and a 12V battery under the bonnet to switch the power on to the 48V battery, if the 12V battery does not shut down but keeps supplying power to an external device like a dash cam hard wired into the fuse box and unless the dash cam has an in line voltage cut off set to 12.4v then the battery will be constantly drained if the dash cam is set to parking mode. Thus depleting the 12v battery to below what it needs to fire up all the other electronics including the 48V battery that starts the car and all else. My dash cam is set to its lowest power ebb of collision mode at level 2 ( almost no drain at all) but because it does not have a voltage cut of for 12.4 V but only 12.0V that is enough drain to take the 12V battery below its starting power. This is from what I have understood but i am no modern car engineer and am not sure how it all works.
Hence i was looking at attaching a solar powered trickle charger ( I live on the costa Blanca south and get a lot of sunshine even in winter) which would keep the 12V battery topped up enough to keep it above its go to sleep cut off level.
The negative battery terminal in these new MHEV cars is part of the issue as it sensors read anything that's attached to it is keeping the system awake and therefore draining the battery.
So if I purchased the solar charger I would have to connect the negative battery connection to a body work bolt to override the negative terminals sensors. Thats as far as I understand but i cannot seem to find anybody who can point me in the right direction if my understanding is correct or not?
If you are thinking of purchasing a car with a modern MHEV system its worth checking from the manufactures if there will be an issue. I have tried SEAT and VAG and got no answers.
Good luck to you, I feel I wasted my money purchasing the dash cam and having it professionally installed so as not to invalidate the cars warranty.
It's just when you said fuse as in singular, I'm wondering how you managed to hardwire a battery protect kit as it needs to be wired to two fuses; a switched fuse and a constant power fuse?
I'm not quite following what you are saying, but it seems like you are saying the car's safety system is set to 12.4V, but your dashcam hardwire kit is set to 12V, so it drains below the safety level. But how can the dashcam overide the car's BMS safety level?
Been thinking about a lifepo4 battery packs, would it be a potential solution to get one with a USB output port (such as the BP100) and hook up a USB powered fan to pull heat away from the battery pack? I believe when the car is off and it's only powering the dashcam, it should sit roughly at ambient temperature, so would a fan be enough to keep the temps in check? I appreciate that this would probably double the power draw from the battery pack whilst the car is off, but that should still give you 12+ hours of recording for one dashcam. When the car is on and chargin the battery pack, you could use the car's a/c to cool it cool.
Most of the battery protect kits I've used allow me to set the cutoff voltage. But now that I'm using the BP100 it's no longer an issue. I just want to make sure that there are switching and constant live fuses and specifically, constant live fuses on a high amp fuse bar as I need ~11A overhead.
I would suggest if you are not skilled with hardwiring via a fusebox, you consider purchasing an OBDII to hardwire instead.
I would suggest if you are not skilled with hardwiring via a fusebox, you consider purchasing an OBDII to hardwire instead. I am not sure if other brand OBDII work with Vantrue, but Thinkware has built an OBDII that is geared towards Electric / Hybrid vehicles if the Vantrue OBDII encounters issues.
Thoughts anyone?
I have already tried the OBD kit and all that does is confirm that when the car power is supposed to go to sleep the OBD kit stays alive and on the green window readout the voltage dropped from a healthy 12.6V to 11.4V once all the other items in the car switched off so it confirms a continuous battery drain, so that will not work, but also SEAT sent me this:- Avoid the advice to use an OBDII cable. The OBDII port on a mild-hybrid VAG car is directly tied to the gateway computer. Plugging a constant-drain device into it is the fastest way to trigger a dashboard error light.
I received this from SEAT :- For your MHEV. Standard hardwire kits require tapping into two fuses (one Constant, one Switched) so the camera knows when the engine is off. However, in your 2021–2026 Seat Leon eTSI, the computer shifts power around the fuse box even after you lock the doors. Tapping a "constant" fuse can accidentally keep a vehicle sub-system awake, causing the car to throw a drivetrain error.
It might be possible that an add-a-circuit with the hot side connected the wrong way around could be causing the backfeed voltage. But, if it's simply any sort of additional current draw whilst the car is off that is preventing the ECU from going to sleep, then a battery pack is probably your only solution because it will only draw current from the car whilst it is switched on.
A battery pack at over 200 euros makes the whole deal un economic, I have already spent over 300 euros with the camera and a professional installation
