swissboy
after trying 3 Power Magic EZ is not possible to use it on Audi!
The customer service from Blackvue is miserable, I wasted a lot of time unnecessarily without solving the problem. They told me that the PMEZ was a new model but it doesn't work the same and the service doesn't answer anymore, they ignore the problem. For many months I have had the cam and I have to use it with the cigarette lighter socket with flying cable!
The first PMEZ no go ON
The 2 and 3 go ON may no go OFF!
FIRST PROBLEM
Switches 1 and 2
setting 1) 11.8v on on
setting 2) 12v off on
setting 3) 12.5v off off
Battery voltage = > 12.1 v
With a battery voltage of 12.1v the PM should only supply power with setting 1 and setting 2.
instead with
setting 1= does not switch on but should switch on
setting 2= should turn on and turn on
setting 3= should not turn on but turns on
so I assume that the processor programming is wrong or the label on the PM is wrong
SECOND PROBLEM
Parking switch = off
with parking switch = off, if ignition is switched off, the PM should stop supplying power
but it won't go off! The cam stays ON all the time, even closing the car and waiting for some time.
There is practically no way to turn off the cam with no settings except by disconnecting the PMEZ
FIRST PROBLEM
Switches 1 and 2
instead with
SECOND PROBLEM
