Power Magic Pro turns OFF, mystery?
Lionhart127
This is a copy sent to BlackVue UK:- Purchased a Power Magic Pro for my BlackVue550GW front and rear cameras after the previous older type of parking mode unit failed me (totally dead). The new Power Magic Pro does not work properly either. I used to work for an electrical supply company so I DO know what I am doing. I am using 2 suitable fuse connections on my late 17 Mini (+ACC) and (+BATT). Checked them with a multi-tester and checked after leaving and locking the car for an hour connected to the tester. The +BATT has a constant supply. However when I connect the Power Magic Pro, it turns off the cameras after ignition is switched off, in the ON position? I then check the connection again on the white pin connector, yellow (+BATT) there is still power? So why is the PM Pro switching off? Now the uncanny part of this is:- When I connect the PM Pro to a 12v model train transformer, the PM Pro works fine, and then I disconnect the red (+ACC) cable it still stays on, as it should do in the on position? Why it will not work on the car, is a mystery? Can you explain this. PLEASE? I have had 2 hit and run bangs on my car in 5 months and I am desperate to get the parking mode working on the cams. PLEASE HELP IF YOU CAN. In the meantime I will have to return the PM Pro for another replacement. Hours and hours of wasted time!
SlickMachine
I wish I could offer some help here but I can't. I think you've experienced what I and several others have: a low quality product not doing what it's supposed to do with any degree of accuracy or reliability. What are the exact voltage measurements from the car when the pmp decides to shut down? Also, exact voltage from the train transformer? My previous PMP would typically shut down at about 12.2v (sometimes) despite being set at 12v shut off. I returned that because it degraded to that point, the new one functions as intended (for how long I don't know.)
L
Lionhart127
Just checked voltages. The model train trans is 12.28 volts. The car fuse is 12.15 volts. The cut-off on the PMP is set for 12 volts (+- 0.1). So it should only cut off between 11.90 to 12.10 volts. So the PMP is inaccurate and is not fit for purpose. The lowest cut off at 11.90 volts, in my view is too high. It should be about 11.5 volts. 2 HD cameras running for 6 hours or more could drain a car battery down close to 11.5 volts, especially if the battery is little weak.
Lola
Maryland
Mobius, A119
First things first, have your battery checked to see if it's OK, a bad battery can play lots of tricks on you.
M8TJT
Bexhill, East Sussex
My two PMPs both shut off at almost exactly 12V (measured with a DVM) when set to 12V but they take about 12.25V to initially fire up though.
I assume that when you switch on and start the engine, it actually switches ON then drops out with ignition OFF and the battery falls to 12.15V?
If yours is dropping out at 12.15V, I would return it as faulty.
I also think your battery is suspect as it shouldn't drop that much off load for quite a while after switching off the engine.
L
Lionhart127
I would think that if the battery is not falling below 12volts, then that is ok. My car is a late 2017 Mini Cooper S, and the mileage is only 5,600. So we are not referring to an old car with high mileage.
jokiin
Too many ¯\_(ツ)_/¯
A car that doesn't do a lot of miles can run a battery down much quicker than a car that gets driven a lot
SlickMachine
I'm on my SECOND PMP, first one failed. This one I've been running for 6 months and as of yesterday it went from running minimum 12 hours in parking mode down to 5 minutes. 5 minutes after shutting off ignition, PMP shuts off. This is such a crap product.
Sent from my SM-G965U using Tapatalk
SlickMachine
Just measured voltage at the PMP, 12.25 and PMP is set to 12v.
Is there a similar product from a different company that would actually work as intended? I'm super sick of this.
Edit: I toggled all the dip switches and returned them to the 12v/infinity position, camera ran all night. Lol.
Hillbilly
Sunshine Coast
DR750s x2 DR450 x2
As in the other thread about similar problems. Turn the engine on and see what happens
Ralph2
Edmonton AB
BlackVue 650GW in 2011 Highlander
Perhaps the accuracy of those meters should be questioned as well.. When one starts measuring the voltage of a moving target... a single measurement with a cheap meter just might not be that accurate.
M8TJT
To which meters do you refer?
SawMaster
SC
G1W-S, G1W-HC, G1W clone, B1W, N2 Pro, K2S, B2W, (ex Mobius)
In my experience with several cheap DMM's they have all been fairly accurate with voltage measurement (within a few percent) or they were wildly off or outright dead. I think most are generally accurate enough for this use.
SlickMachine
I've gone through 3 PMPs so far and what I have found is that they start off working great but eventually, after a couple months of use, the run time in parking mode will degrade from almost an entire 24 hour period down to about an hour, sometimes much less. I changed out my 3rd PMP about 3 months ago because it was shutting off pretty much immediately after I turned my truck off. When I swapped it out, the new PMP would run 20+ hours (magically it would find enough voltage where the older unit couldn't), 3 months later it's back to shutting off almost immediately. Without disassembling the unit, I'm guessing they use a small capacitor somewhere to smooth out voltage and that capacitor just degrades over a short time, just like any battery would. Those of you with success with this product- I would attribute that to luck or maybe an older build with different components or perhaps your vehicles electrical system. Either way, I've been through 3 of them and they all behave in the manner I just detailed above. Completely unreliable and I'm in search of a new solution that doesn't involve giving blackvue any more money.
