Yes, you can run 2 cameras from a single 12v socket, providing that you get a good quality 12v-to-USB splitter. You should look for a minimum of 1A from each port.HI! Is it possible to run 2 cameras off 1 power supply -??
Approximately how many hours do u get from 64gb SD card. Thks
if that's a power splitter then you should have or get a multimeter to monitor the voltage and amperage that your cameras get because the voltage may drop below the cameras need to start and they will go into a boot loop possibly damaging SD cards and / or a firmware on your cameras.Cigarette Usb Lighter adapters are not live unless the key is not turned on,, therefore i will be using the above Y cable with separate power to live wires for 2 dash cameras.. Thks.
A | A119 Will Not Power On in Any Situation | A119 | 5 | |
N | Purpose of hardwire kit and what if car has continuous power to cig lighter | A119 | 3 | |
D | Start with ignition when hardwired, but also power for parking | A119 | 9 | |
A | using a119s with vico power | A119 | 13 | |
E | A119 Question about power supply | A119 | 9 |
