You can try, but any misbehavior you might experience will probably be lack of power related, and you will probably get that issue so keep a close eye on your cameras performance on such a charge port.
The provided PSU / power cable you can snip off the 12 V plug that would normally go into your cigarette lighter socket in the dash or console, and then use the 2 wires exposed to tap into your fuse box for a stealthy install.
Thats the reason SG power supplies have the 12 V - > 5 V converter a bit up the cable, that way you sort of get a hard wire kit too,,,,,, that just do not support parking guard features ( for that you need the dedicated 3 wire hard wire kit )
It is Funny car makers put such weak charge ports in their cars, it will take you forever to say charge a pretty flat phone, at best you can replenish the power the phone use as you use it in the car for whatever.
I once used my 7" tablet for navigation, but even though it was plugged in to charge meanwhile and fully charged from the get go, well it slowly discharged anyway as the charger i used was too weak to both power and charge the thing.
So had i set off on a really long drive with that setup sooner or later my charging tablet would have run out of power.
