View attachment 4015 ]
Easy as What year Passat is it I have a 2011 TDI wagon Buy two addafuses and put them here in the right hand side of the dash One is permanent power and the other acc power only.
Cant remember which is which but not hard to figure out There is a screw above the fuses for the earth Just clamp a ring on the earth wire and put it under the head of that.
You also need to fit two bullet connectors to the PM wires
All done in 10 mins Feed camera wire (Black wire in pic with trim showing) up the side of the dash and up the front of the A pillar next to the screen and across the front of the headlining to above the mirror Best to pull the wire up and plug it in the camera and then tuck it away from the camera end and tuck the extra in the dash.
Feed the wire as in Pic 4 I cut a small piece out of the edge Just above and to left of camera lead as when you put the end plate back it can pinch the lead The screw in the other pic is NOT the one for the earth which is further in above the fuse box The bubble wrap is around the PM and the ciggy socket to stop rattles
