I followed Viofo instructions exactly and tried everything I can think of with multiple formatted SD cards in PC & Mac for literally hours and still I can not get 1.5 onto the camera... What am I doing wrong?
oh I didn't know you have to chase the file name... Why didnt Viofo say it on their Firmware web page
you shouldn't have to, make sure you have the correct file, don't go renaming a different firmware file
and your SD card must be formatted with a Fat32 file system.I followed Viofo instructions exactly and tried everything I can think of with multiple formatted SD cards in PC & Mac for literally hours and still I can not get 1.5 onto the camera... What am I doing wrong?
FWA129.bin
Rename the file to the name above and try again
Sent from my iPad using Tapatalk
yes, the firmware file name is specific to a camera. any firmware version for A129 (for example) must have the same file name = FWA129.bin, including MOD firmware..Sorry, I don’t want to cause the OP any problems. I updated to v1.5 4uj and had to change the file name to make it work, info taken from the first post in the Mods parking firmware’ thread
I can see the file on the Viofo site should already have the correct file name.
thanks OK, I will eventually try out the mod versions. I just wanted to get the 1.5 on to check out the hard wire parking modes. thanksSorry, I don’t want to cause the OP any problems. I updated to v1.5 4uj and had to change the file name to make it work, info taken from the first post in the Mods parking firmware’ thread
OK Thanks I caned it like you said and it worked! Thank you so much. What a headache this was for me. Very frustrating following instructions from Viofo over and over and all I had to do was re-name the bin file. Would of been nice if @viofo said that in their instructions Thanks for the help I finally can get this back in my car thanks again. Have a happy holidays guys and all the best thanks fo the help
the modified firmware needs to be renamed, he mentioned Viofo instructions though, if it's the original firmware it isn't an issue, if using Linux or a Chromebook though it is necessary to rename the file extension from .bin to .BIN or it won't load
lol now I'm stuck in the EV mode while I was configuring my cam. I am having bad luck today. I went down the menu to check each setting and when I got to EV it will not let me get out of it so I can continue checking the other menu settings. This is ridiculous. lol
yes the disconnect from power and re-connect got me out of stuck menu EV parameter. I must of power cycled this cam over 80 times trying to install the V1.5 firmware, and wasted over 2 hours of my time because @viofo neglected to put in their instructions "make certain you re-name the file". Last time when it went from 1.2 to 1.3 they left the 1.2 on the bottom of the page and the 1.3 on the top of the firmware page and that time I kept updating my 1.2 to 1.2 not knowing that there were two separate files at that time. I wasted hours with it then too, its so funny that its pathetic lol. thanks @viofo
J | Viofo A129 Duo Parking Mode Problem - Please Help | A129 / 129 Duo | 11 | |
A | Problem with Parking Mode ? | A129 / 129 Duo | 4 | |
A | NEW camera sended by viofo have problem after returning PRO :/ | A129 / 129 Duo | 0 | |
A | HCK3 or Software not hardware problems parking mode solution? | A129 / 129 Duo | 2 | |
Y | hardwire problem | A129 / 129 Duo | 6 |
