Problem with taking picture
eidur
Malaysia
Hello everyone here!
Does anyone has problem of the camera freeze up after taking picture, but it works perfectly recording video?
I've never had that problem but I'll take a stab at some troubleshooting.
1. Are you sure you have a genuine SJCam? For example, there's a security code found under the scratch-off on the side of the original box. You can enter that number on the SJCam website to verify its authenticity. https://sjcamhd.com/safe/
2. Do you have the latest version of the firmware? You can check the version on your camera by going to Page 6 of the Setup menu and selecting Version. Then go to the SJCam website to check for the latest version. https://sjcamhd.com/sj4000-series-firmware/ You can update your firmware if you don't have the latest on your camera. Note that if you have a counterfeit camera a firmware update is likely to make things worse.
3. Do you have a memory card from this list: https://dashcamtalk.com/forum/threa...y-cards-compatibility-list.14627/#post-204780 These are memory cards that Dash Cam Talk members have reported work well in their cameras.
4. Is Capture Mode turned on or off? If on, a clock face icon will appear below the camera icon on the Camera mode screen. You can go to Page 1 of the Setup menu, select Capture Mode and make sure it's set to Single (i.e. turned off).
These would be my first best guesses. Good luck :)
