Q200 Wiring Question ?
152bobby
Wokingham
Thinkware Q200, 2CH, 256GB, OBD2/F200 2CH Pro/Vantrue E1 Pro
Can anyone tell me out of all the Thinkware Dashcams, which ones are compatible with my existing Q200 wiring ?
I'm just considering my options of upgrading to a better spec set up on a budget 🀣 and ideally, possibly use the existing rear camera.
Cheers
Cheers
Hi there,
Unfortunately, there's no compatible dash cam with your Q200 wiring except if you are using a hardwiring, OBD II power cable or a 12V power cable.
Sorry, I should have mentioned that. I'm using the Thinkware OBDII to power them.
So does that give me options ?
Thanks for your reply 😊
OBD II power cable is compatible with all Thinkware Dash Cams except F790, but the rear camera and its rear camera cable need to be replaced if you are switching to another Thinkware Dash Cam model
So a COMPLETE swap over, except for the OBDll cable 😭
Hi,
Is the wiring for the F200 and Q200 the same ?
My daughter has the 2 Channel F200 in her car and I'm thinking of giving her my 2 Channel Q200.
I'm hoping it's just a case of unplug the cameras and reconnect πŸ‘
Cheers
Hi,
Cheers
Hi there, yes, they are compatible
Just so that I'm 100% sure...
My daughter has the F200 front (1080p) and the F200 rear (720p), if I get the Q200 (2k) and the Q200 rear (1080p), I don't have to change ANY of the wiring at all ?
If I was being tight fisted, would her existing F200 (720p) rear work with the front Q200 ?
Cheers
Cheers
Yes, the F200 rear camera is compatible with the Q200 front as well as the rear camera cable
