So I have set the 0805 up and tested the recording having set all the settings I want. Now I want to be sure I have it set up so that if someone hits my car while it's parked then it will capture the event. So as I understand it if the g-sensor is active then should the car feel the force set (default setting is 2.5g) then it will record for 10 seconds and then shut down. Same also for the motion detector should it pick up sudden movement around the car.
Am I right in thinking that even though the device is powered off it will still power on using the internal battery and record for 10 seconds? I ask because I have tested it by banging on the windscreen and moving my hand back and forth in front of it, yet nothing recorded.
I've tried a few different g shock settings too which brings a final question. Is a lower g sensitivity going to record smaller impact? So 2g will only take 2g of force to set it off but 4g would require more force thus it would take a bigger bang to set it off?
Thanks in advance.
Thanks in advance.
