rdCAM player first preview version
Yes I have the folders.
And the GPS log files also.
Then I'm out of idea. The GPS data automatically load on my end. There were no configurations to change at all.
GPS log files do contain data.
Example;
A,111117,174325,4259.1939,N,8346.3395,W,3.8,0.43,0.77,0.07;
A,111117,174326,4259.1962,N,8346.3394,W,6.5,0.43,0.70,0.12;
A,111117,174327,4259.1995,N,8346.3395,W,9.6,0.44,0.77,0.10;
A,111117,174328,4259.2042,N,8346.3395,W,13.6,0.59,0.67,-0.30;
A,111117,174329,4259.2099,N,8346.3396,W,17.4,0.35,0.74,-0.12;
A,111117,174330,4259.2157,N,8346.3397,W,19.9,0.38,0.77,-0.09;
A,111117,174331,4259.2216,N,8346.3399,W,21.0,0.38,0.72,-0.16;
downloaded and installed without issue; will be testing
Anybody else have issue with this player. I can't get the video to display and the audio is choppy. Trying to find a player that will play front and rear camera videos in sync with each other with GPS and map data (if there is such a player...I'm still new at this)
[QUOTE="NLV45, post: 383015, member: 39275] I can't get the video to display and the audio is choppy. [/QUOTE]
can you show more details?
and can we know your computer configuration? CPU / DDR / GPU
if this player not work, you can also use DashCamViewer.
Hello @Rayman the computer is HP laptop dual core 2.2Ghz with 4 gig of ram integrated graphics running on Windows 10 home 64 bit..
When I run rdCam viewer program the player shows what videos I have on the SD card in the lower right window, but when i go to play them, the player video screen is blank. The audio plays but is broken up and the GPS map shows the location in the upper right window.
The videos play fine when i use DashCam Viewer, however they do not have PiP support for Windows OS. So I can't synch up front and rear camera videos. To play at the same time.
have you changed the default folder path?
or please have a try to install K-lite codec pack?
Yes I change the default folder and load the file straight to my hard drive. I still have no video and the audio is choppy when using rdcam viewer.
I installed k-lite codec pack and used the built in viewer and the video and audio files play good. But just like with dashcam viewer, I can't play the front and rear cam videos at the same time.
bingo, that is the reason.
the rdCAM player will identify video path according set rules. when you open the program it will auto scan the microSD card.
if you want to copy the videos to computer, please use the "ADD FAVORITE" button to backup the videos to hard driver. the backup folder path can be set in program.
that might explain why I could never get it to load anything, will give it another try
Humm....still not working. No video and the audio is choppy
This would be good if it gets finished as I too would like to see front and rear cam video in sync on a Windows machine.
Will watch this with interest.
So will there be a mac osx version?
Hi
On the rdcam.com website it says the latest version is 1.1.1, but the download link is broken. I've got 1.0.4.
Can @Rayman.Chan please fix the link on the website, or post a new link here?
Thanks & Cheers,
Tinu
Old thread i know. And raymond chan seems extremely busy. Just a quick feedback. Viewer works nice, looks cool. Just wish to have a slowdown button to view those time lapase video comfortably.
Phil B mini0906 5
Similar threads
Compatible Media Player?
