Depends on the size of your sensor, with an IMX322 you can probably use an f1.0 for DIY; with an IMX678 f1.4 is probably the limit.I believe the DoF is not a problem with such small sensors. Overexposure in bright sun and bad contrast due to some flare effect seem to be an issue here (and the lens price of course ).
How do I confirm & verify manufacturer claimed specifications for Lens Aperture?I note that Viofo have decided to use an f1.8 for the new A229 cameras.
I think you would need to remove the lens from the camera and measure the optics, but on a dashcam size lens that is going to be very difficult to get accurate.How do I confirm & verify manufacturer claimed specifications for Lens Aperture?
If I disassemble the camera will it be written on the lens?
I’m now suspicious of all manufacturer claimed specifications.
All specifications should be confirmed & verified.
The production / retail A119 Mini 2 (May 2023) had an F1.6 specification.I'm sure some of the specifications will be wrong though, especially in cameras that have had their lenses changed since their specification was published. Such as the A119 Mini 2?
Absolutely not.So don't worry about it.
F1.6 140° = A119 Mini 2 (May 2023)
F1.6 140° = A119 Mini 2 (July 2023 updated lens)
I think you may find a fault when you verify the first quote, Reagan was correct, although it is actually a Russian rhyming proverb that Reagan learned and put to good use.“Trust but verify”
-Ronald Reagan
The good thing about aperture figures is that they are not affected by actual image FoV, they are already corrected for lens FoV.99° FOV = A119 Mini 2 (May 2023)
114° FOV = A119 Mini 2 (July 2023)
So I expect that all A119 Mini 2 have the same aperture, the same sensor, and thus the same brightness of image on the sensor, whichever lens they use, thus you can use the same firmware on all versions and the exposure will be correct.
Not sure about better, I think they wanted a lens closer in FoV to the A119 V3 since it is an A119, but ended up with A129 FoV.I suspect you are correct here. I believe they simply replaced a flawed lens with an almost identical one with better quality and dimensional stability.
Personally I would choose the wider lens, but people in places with smaller writing on their licence plates than the UK may well think the narrower FoV is better, the V3 has been very popular.
Don't know what happened on the temperature stability, but I guess that production lenses didn't match test lenses, and when problems emerged they switched to the well proven and trusted A129 lens instead of trying to sort the quality control issues on the narrower one.
As I know, SG doesn't has a dashcam uses a 7G lens.It's always amusing how you present yourself as a "dash cam expert" in order to garner attention and receive thousands of dollars worth of free merchandise when you know so little about how cameras, lenses and photography actually work.
Your paranoia and suspicion about alleged false manufacturers specifications are rooted in your ignorance about optics.
Lens specifications from the manufacturers, even for the less expensive ones are really quite accurate even if the quality varies. As Nigel points out, it is mathematical. You can't fake lens aperture claims if you are a lens manufacturer, although I guess someone selling on eBay or Amazon could claim anything they want, but that's not what we're talking about here. And Viofo certainly can be trusted to provide accurate lens aperture specifications.
The fact is that anyone who is knowledgeable and experienced about optics can pretty much tell rather quickly if claimed specifications such as aperture are accurate, along with a wide range of other optical quality parameters just by carefully examining the images produced by the lens under different conditions. For example, images from a ƒ/1.2 lens and a ƒ/1.6 lens or a ƒ/2.0 lens will appear different and would be obvious to anyone who knows what they are looking at, regardless of what sensor is used. The difference in light transmission between a ƒ/1.2 lens and a ƒ/1.6 lens and an ƒ/2.0 lens is dramatic.
The one piece of marketing BS we do get from dash camera manufacturers regarding lenses, including Viofo that really irks me are the bogus claims about the number of lens elements. It is based on the "more is better" marketing falsehood.
Viofo, Street Guardian and others often claim that their lenses have "7 elements". The fact is that these lenses really have only 6 individual lens elements but the IR-cut filter is included as an additional "lens element" to increase the apparent number to 7. This is the "more is better" bogus marketing scheme intended to influence most people who have no knowledge of lens optics.
I recall that Jokiin from Street Guardian started this trend as a marketing ploy and others ran with it.
This image is from the Street Guardian (OCDtonic) web site to illustrate my point. It applies to all their lenses. Viofo does the same in their promotions.
The number of lens elements in a lens has literally nothing to do with the quality of images a lens can render. Some of the finest, sharpest lenses ever made have only four elements. For example, the superb, incredibly sharp 50mm Leitz Elmar ƒ/3.5 lens that shipped with the original Leica 35mm camera and was available for nearly 40 years had only 4 lens elements. Today's computer designed, multicoated lenses are more sophisticated and generally do have more elements but more is not necessarily better and in some circumstances can even be worse due to decreased light transmission from all that glass, but in any event a lens filter is not a lens "element".
In all of the lens spec documents, the IR cut is listed separately.
While we listed it is a 7G lens, it is a true 7G, like we used on A129 Plus.
The A129 Plus lens is not cheap, as I know, almost no other dashcam company use this lens as it is too expensive. And the 2K quality difference is not obvious in some condition.
This is the A119 V3 lens structure.
For other cheap lenses, it will not declare it uses all glasses, like this.
It is worth pointing out that it is not just the FoV that is important when comparing these lenses. The V3 lens has quite low fisheye compared to the wider lenses, so although the wider lenses have a wider FoV, the amount of magnification for reading the plate directly in front of you can be almost the same, giving you the best of both, but with some people complaining that they don't like fisheye!Personally I consider the A119 V3 and Mini 2's narrower lens to be one of its more appealing features. At least for me the lens suits my needs very well for my vehicle as I use the cameras for both front and rear along with side cameras that overlap the front and rear coverage.
I don't have a fisheye figure for the A129 Plus lens, so I'm not sure how the two Mini 2 lenses compare, but the original Mini 2 lens appears to have the flattest (least fisheye) of any lens other than the A129 Pro (a lens with low fisheye for making 4K road movies).
It would be good if @Panzer Platform gave us the actual fisheye as well as the actual horizontal FoV figures... the information is on your test rig images if you don't mind a little mathematics, or using a spreadsheet! Dashcam manufacturers never give fisheye in specifications, there would be even more problems than with FoV!
You just need a bit of trigonometry, that's all.
Angle of view (in degrees) = 2 ArcTan( sensor width / (2 X focal length)) * (180/π)
This is the formula that is most commonly cited for angle of view, and it agrees with the way in which lens specifications are presented by major camera manufacturers. (Although not necessarily dash cam manufacturers who tend to often just make stuff up.)
FOV would add a distance component:
Field of view = 2 (Tan (Angle of view/2) X Distance to Subject)
I gotta hand to you Mellow, you have mastered the art of overcomplicating things.
You might as well be speaking Pig Latin Hieroglyphics with a Scottish accent.
You’re really making me feel inadequate with your crazy maths.
The real value would be coming up with an explanation that could be understood by the average consumer with a bellow average IQ, (me). lol
