Rear Window hardwiring B40-A118 Dashcam not long enough
zakdk
Bought one of these from ebay https://www.ebay.com/itm/331798745762 to hardwire the dashcan from the rear window to the front fuses but its not long enough ,whats the best solution ??
Has anyone come across this problem.
As @Gibson99 says. Just extend the red and black wires with speaker wires to wherever you want to connect. Red-positive. Black-ground. Good luck.
Avoid cheap hardwiring, especially if you want long extension. They may cause interference and other issues.
Best if you can hardwire into some electrical loom in the rear of your car ( reading lights etc .) but don't forget to add a fuse as well.
thats what i had in mind as it is the easyiest setup and its ot long to pick up interferece,will keep you posted ,thnks all.
