Recording stops
Denis53
NSW
Blueskysea DV988 Street Rod, B4K Ute
A question for the guru's out there, don't know if i have accidentally changed a setting but last 2 times out the dash cam DV988 has stopped recording front and rear after 5 or 6 minutes but then doesn't start again until unit powered off and i go out again? Not hard wired, just plugged into cig lighter socket.
Any suggestions.
Many thanks
Denis
Use this USB power cable?
Set up its parking mode function off in the camera menu and keep eye on it to see if it works normally!
Thank you estore009, using the usb cable supplied and have turned parking mode off, don't use it anyway as car has battery isolation switch that is turned on when car parked. Not going out now until monday or tuesday so will let you know.
Many thanks
Denis
