I never use it more than 1 meter down so I don't know, but I'm guessing the red preset is a lot too red for most purposes. You can select your own redness with the custom.Wondering if the red white balance is as effective as a filter. Not been able to find any video which demos the red wb.
Doing it when editing is similar, but when it gets compressed into H264 to store in the video file, the stuff it thinks you cant see gets lost, if you then try to bring it back by turning up the red the stuff that has been lost can no longer be made visible, if you do it in the camera then nothing gets lost until after the WB correction so you should end up with a more detailed image by doing it in the camera.I assume that tweaking the wb when editing the video would have the same effect as setting the wb in camera. Still, is seems a shame that the Git2 case isn't compatible with the filters. I could get a red filter for inside the case, between the lens and the port, then I'd only have the stuff near or on the surface to colour correct during post production.
Edit: Just found these on the Canadian GitUp site - http://www.gitup.ca/en/home/25-colorful-under-sea-filter-6-colors-included-for-gopro-git1-git2.html need to see if I can get them shipped to the UK.
It would use useful if the the firmware could be updated to allow assigning switching WB modes to the side button.I think that the custom white balance is better than the filter, as any kind of supplementary glass or plastic in front of the lens will reduce light and quality.
The Gopro 40 meter cases are really inexpensive on EBay , but I only found inexpensive adapters for the case in 52 mm size which may cause vignetting with wide fov .I assume that tweaking the wb when editing the video would have the same effect as setting the wb in camera. Still, is seems a shame that the Git2 case isn't compatible with the filters. I could get a red filter for inside the case, between the lens and the port, then I'd only have the stuff near or on the surface to colour correct during post production.
For me, major reasons to buy the Git 2:the mic. access and Gopro case fit!Gitup Canada cancelled my order without explanation. In the end I ordered the official Gopro underwater case with the Backscatter Flip4 filter.
How is this, do you have any video with it?Flip4 and GoPro housing here, expensive but a very nice solution.
If you are in green water a magenta filter will improve the image a little. Chinese sellers on Ebay have the slip-ons for inexpensive, also the hero4 40 m.cases in blue and green tint!Got a question, I just gut the Gitup2 and will go oversees for 2/3 months. I won't dive but will doe snorkeling. Or maybe underwater for max 3 meters. Do I need some filters then? Like the Backscatter Flip4 filter above?
if you can get to 60m below surface while snorkeling, you need to call Guinness. and I don't mean the beer company!If you are in green water a magenta filter will improve the image a little. Chinese sellers on Ebay have the slip-ons for inexpensive, also the hero4 40 m.cases in blue and green tint!
Remember the Gopro 60 m. waterproof case is the one with the ring of visible screws andlarger dimensions.
Compatible underwater case? | Git2 | 3 | ||
A | Macro Filter to fit on Git2P housing | Git2 | 0 | |
H | ND filter for 90 deg | Git2 | 14 | |
Filters for Git2. Yes or no, that's the question | Git2 | 4 | ||
S | Filter set for Git2? | Git2 | 2 |
