Ratbat
- Jul 17, 2019
- Ramsgate CT11 7RP, UK
- United Kingdom
finally got fed up with my garmin 55 and having liked my 312 before, thought i'd get the 522....may have been a mistake.
I use parking mode, and its hard wired.
using the app, will stop the cam recording, you need to manually turn it back on.
(can we get a button in the app to check the cam is recording and start if not?)
cam will shut off if the car doesn't move for a few mins when car is running
every morning when i unlock and open the car, i get a parking mode protected file
(can they not program it so if the cam is powered on then any prot files in the last 5 mins get unprot??)
alexa has bugged on me a couple of times, locked up the entire cam, had to remove from power and reset
you cant (as was advertised) use alexa to send vids to your phone, feature not implemented yet.
no alexa spotify integration (an alexa issue not the cams fault)
im hoping a lot of these can get patched, and at least the horrid startup noise has gone that the 312 had
