blackpanther
- May 11, 2016
- Canada
- 2x A129 Duo, 2x B1W
Hi folks,
I have a G1WH purchased in January 2014 which is showing its age. I have replaced the battery twice, but a battery-equipped camera does not seem to be the right choice for my purposes (capacitor would be better I think), and the battery is dead again. I could deal with this issue, but it seems as if the lens has become damaged by sun exposure (one side of the image is blurry) so it's time to look for a replacement.
Some considerations to be aware of:
I own 5 vehicles, and wish to have one camera which I can freely move between vehicles. This means the mounting mechanism should be easy to release and also fairly durable. The G1WH has been fine in this regard; I've got mirror mounts in each car and can move the camera easily. Ideally, the new camera will use the same mounts, but I understand this may be impossible.
All of my vehicles leave the cigarette lighter socket hot at all times, not interrupted by the ignition switch. If I were to hardwire the camera (this is preferred but I haven't gotten around to it yet), the same would apply, hot at all times. I would like to have the camera remain 'on' 24/7, and only record when it sees motion.
I do not care about GPS.
I would like to be able to connect to the camera wirelessly, such as from my smartphone, so I do not ever need to remove the microSD card from the camera. If the camera has this functionality, then I am not worried about the size or quality of the screen on the camera.
I do not need a rear-facing lens, but will consider cameras equipped with them as long as the rear lens records to a separate video file than the front lens.
I like the Chupad D501, but am concerned about how it mounts. It does not look like it would be easy to move between vehicles. I think the perfect choice is a G1WC with Wifi, but unfortunately that doesn't exist.
I appreciate any suggestions you can make to help narrow down the options on the market. Thanks!
