Replacement cable for rear cam?
shempz
Hi all,
The 6m rear camera cable for my 512GW is not working any more - anyone know where I can get a replacement (to be honest a 4m or 5m cable would do rather than the 6m supplied) - unless my google skills are waning, it seems pretty tricky to find a micro-mini usb cable? Or will I just end up having to buy a normal micro or mini usb cable and get an adapter?
Thanks in advance.
Tony lovelock
Hampshire
Nextbase 422gw/Nextbase 212G & möbius C3 wide angle lens
I always buy my replacement mini usb cables from this company check out the link!
Tony lovelock
Hampshire
Hopefully it’s still under warranty? Next base will send out a free replacement
S
shempz
Thanks - the oem cable has one mini and one micro usb end - which is non-standard, hence why I asked if anyone else knew where to get one. A standard cable like you suggest might only work with an adapter.
M8TJT
Bexhill, East Sussex
And there again, it might not.
May I refer you back to post #3?
